[GSoC]problem in POSIX Key test case under classic API
Wed Jul 25 17:50:25 UTC 2012
classic semaphore should be able to adapt to your needs. I don't know
if there is a classic version of a condition variable..
On Wed, Jul 25, 2012 at 8:35 AM, Ashi <ashi08104 at gmail.com> wrote:
> Hi, all.
> I'm working on the test case of POSIX key under unlimited RTEMS tasks(the
> psxkey08 test in psxtest directory), that tests whether POSIX Key works when
> called by classic API under unlimited task configuration.
> I've done the similiar test case in POSIX API. They share a similiar
> workflow: in POSIX API test case(the psxkey07 test in psxtest directory), I
> use condition variable to do thread synchronization. My question is can I
> use POSIX condition variable in classic API(namely, in psxkey08)? If no,
> which manager in classic API should I choose to do the similiar work as
> condition variable?
> BTW, I also use condition variable to do RTEMS task synchronization in my
> current implementation of psxkey08, and it seems also work.
> My work has been push to github:
> https://github.com/ashi08104/rtems/commits/one_rbtree
> Best wishes!
> Zhongwei Yao
> rtems-devel mailing list
> rtems-devel at rtems.org
