[GSoC] lm3s6965 on QEMU issue
Fri Jul 27 03:44:29 UTC 2012
On 07/27/2012 11:40 AM, Hesham Moustafa wrote:
> Hey,
> I have applied patches for lm3s69xx BSP and run qemu with this command but i
> get that error
> $./qemu-system-arm -nographic -M lm3s6965evb -kernel
> /home/hesham/lm/arm-rtems4.11/c/lm3s6965/testsuites/samples/hello/hello.exe
> *** HELLO WORLD TEST ***
> Hello World
> *** END OF HELLO WORLD TEST ***
> qemu: hardware error: gic_dist_writeb: Bad offset 4f0
> CPU #0:
> R00=00000000 R01=00000004 R02=00000000 R03=e000e100
> R04=00000000 R05=00000000 R06=00000000 R07=00000000
> R08=00000000 R09=00000000 R10=00000000 R11=00000000
> R12=00000001 R13=20001130 R14=0000014b R15=00000466
> PSR=600001b3 -ZC- T svc32
> Aborted (core dumped)
> Do i have to worry about that? and if yes how could i solve that error ?
Everything works fine.  This error shows that the application terminated
successfully.  I figured out no explicit way to reset the Qemu system on target
request so I have chosen an invalid memory access for that.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
