[GSoC] CSB337 and skyeye 1.2.2
Hesham Moustafa
heshamelmatary at gmail.com
Tue Jul 31 19:47:59 UTC 2012
Hi,
I have tried to apply the patch here [1] to get CSB337 working on skyeye
When i run the script at sim-scripts directory and cat log/hello that's i
got
$ ./csb337 ...../hello.exe
running ...../hello.exe for maximum 60 seconds...
and it hangs
Then i run this command
$cat log/hello
and i got this output
" 1 arch: arm
2 cpu info: armv4, arm920t, 41009200, ff00fff0, 2
3 mach info: name at91rm92, mach_init addr 0x8060420
4 SKYEYE: use arm920t mmu ops
5 uart_mod:1, desc_in:/dev/null, desc_out:/dev/stdout
6 exec file
"/home/hesham/csb337/arm-rtems4.11/c/csb337/testsuites/samples/hello/hello.exe"'s
format is elf32-little.
7 not load section .vector: addr = 0x00200000 size = 0x000005c0 .
8 load section .text: addr = 0x20104000 size = 0x00017eec.
9 load section .init: addr = 0x2011beec size = 0x00000020.
10 load section .fini: addr = 0x2011bf0c size = 0x0000001c.
11 load section .rodata: addr = 0x2011bf28 size = 0x00001984.
12 load section .eh_frame: addr = 0x2011d8ac size = 0x00000004.
13 load section .ctors: addr = 0x2011d8b0 size = 0x00000008.
14 load section .dtors: addr = 0x2011d8b8 size = 0x00000008.
15 load section .jcr: addr = 0x2011d8c0 size = 0x00000004.
16 load section .data: addr = 0x2011d8c4 size = 0x00000a64.
17 not load section .bss: addr = 0x2011e340 size = 0x00001a68 .
18 not load section .work: addr = 0x2011fda8 size = 0x00ee0258 .
19 not load section .comment: addr = 0x00000000 size = 0x00000048 .
20 not load section .debug_aranges: addr = 0x00000000 size = 0x00002970 .
21 not load section .debug_info: addr = 0x00000000 size = 0x0015bc6b .
22 not load section .debug_abbrev: addr = 0x00000000 size = 0x00025767 .
23 not load section .debug_line: addr = 0x00000000 size = 0x0003dd19 .
24 not load section .debug_frame: addr = 0x00000000 size = 0x00004ff0 .
25 not load section .debug_str: addr = 0x00000000 size = 0x0001085b .
26 not load section .debug_loc: addr = 0x00000000 size = 0x0001dc51 .
27 not load section .debug_ranges: addr = 0x00000000 size = 0x00002db0 .
28 not load section .ARM.attributes: addr = 0x00000000 size = 0x00000010 .
29 start addr is set to 0x20104000 by exec file.
I need to get this BSP working on Skyeye as my project depends or its core
i think i am close, that's why i am sending this e-mail hoping to get some
help.
Thanks,
Hesham
[1]
http://www.rtems.org/pipermail/rtems-users/attachments/20070625/ddf6facd/attachment.obj
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120731/01da949a/attachment.html>
