[PATCH 5/6] mghttpd: Clarify comment
sebastian.huber at embedded-brains.de sebastian.huber at embedded-brains.de
Tue Jul 3 08:45:40 UTC 2012
From: Christian Mauderer <christian.mauderer at embedded-brains.de>
 cpukit/mghttpd/mongoose.h |    8 ++++----
 1 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/cpukit/mghttpd/mongoose.h b/cpukit/mghttpd/mongoose.h
index 61a560a..c130fe7 100644
--- a/cpukit/mghttpd/mongoose.h
+++ b/cpukit/mghttpd/mongoose.h
@@ -157,10 +157,10 @@ int mg_write(struct mg_connection *, const void *buf, size_t len);
 // Send data to the browser using printf() semantics.
-// Works exactly like mg_write(), but allows to do message formatting.
-// Note that mg_printf() uses internal buffer of size IO_BUF_SIZE
-// (8 Kb by default) as temporary message storage for formatting. Do not
-// print data that is bigger than that, otherwise it will be truncated.
+// Works exactly like mg_write(), but allows to do message formatting.  Note
+// that mg_printf() uses internal buffer of size BUFSIZ defined in <stdio.h>
+// (8 KiB on most Linux systems) as temporary message storage for formatting.
+// Do not print data that is bigger than that, otherwise it will be truncated.
 int mg_printf(struct mg_connection *, const char *fmt, ...)
 #ifdef __GNUC__
 __attribute__((format(printf, 2, 3)))
1.6.4.2
