disable thread dispatch problem
Ashi
ashi08104 at gmail.com
Mon Jul 9 12:32:57 UTC 2012
2012/7/9 Sebastian Huber <sebastian.huber at embedded-brains.de>
> On 07/09/2012 08:28 AM, Ashi wrote:
>> 2012/7/6 Sebastian Huber <sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
>> <mailto:sebastian.huber@**embedded-brains.de<sebastian.huber at embedded-brains.de>
>> On 07/06/2012 11:49 AM, Ashi wrote:
>> I've a problem of _Thread_Disable_dispatch() function in below
>> code.
>> It's my
>> implementation of _POSIX_Keys_Run_destructors() function. I come
>> across the
>> problem when I run the psxkey03 test:if
>> _Thread_Disable_dispatch() was
>> commented out, psxkey03 can run without problem. when
>> _Thread_Disable_dispatch() added at line 1(as below), psxkey03
>> will fail. I
>> debug it in sparc-rtems4.11-gdb, and find psxkey03 runs into
>> _Internal_error_Occurred() function then stop. I know
>> _POSIX_Keys_Get()(at line
>> 12) will also disable thread dispatch--does this lead to the
>> problem?
>> However,
>> can't figure out where exactly the problem exists, could anyone
>> explain
>> it? Thanks!
>> The _Thread_Disable_dispatch() can nest. I suppose you want to
>> acquire a
>> resource in the destructor which is not free. The path to
>> _Internal_error_Occurred() should show the problem.
>> Sebastian, I follow the calls in gdb, and find the error is:
>> Program received signal SIGINT, Interrupt.
>> 0x020168b8 in _Internal_error_Occurred (the_source=INTERNAL_ERROR_**CORE,
>> is_internal=true, the_error=5)
>> at ../../../../../../rtems/c/src/**../../cpukit/score/src/interr.**
>> c:58
>> 58 _CPU_Fatal_halt( the_error );
> What is the call stack here?
> Hi, Sebastian, the call stack is:
** #0 0x020168bc in _Internal_error_Occurred
(the_source=INTERNAL_ERROR_CORE, is_internal=true, the_error=5) at
../../../../../../rtems/c/src/../../cpukit/score/src/interr.c:58
#1 0x0202ae58 in _Thread_Handler () at
../../../../../../rtems/c/src/../../cpukit/score/src/threadhandler.c:197
#2 0x0202acb0 in _Thread_Handler () at
../../../../../../rtems/c/src/../../cpukit/score/src/threadhandler.c:89
and the info local shows:
level = 4198629
The error=5 is probably INTERNAL_ERROR_THREAD_EXITTED (see also
> Internal_errors_Core_list). How did you terminate the task?
> the task is terminated by Ctrl+C in sparc-rtems-gdb.
However, as I said in my last post, the problem is gone when I add
_Thread_Enable_dispatch() at the end of each while iteration...is it proper?
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone : +49 89 18 90 80 79-6
> Fax : +49 89 18 90 80 79-9
> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
> ______________________________**_________________
> rtems-devel mailing list
> rtems-devel at rtems.org
> http://www.rtems.org/mailman/**listinfo/rtems-devel<http://www.rtems.org/mailman/listinfo/rtems-devel>
Best wishes!
Zhongwei Yao
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120709/ab562bf0/attachment-0001.html>
