[rtems commit] Merge branch 'master' of ssh://git.rtems.org/data/git/rtems
Cláudio Silva
claudiodcsilva at gmail.com
Thu Jul 19 08:29:21 UTC 2012
Hi,
This is why it is advised to always specify the branches that you are pushing:
git push upstream my_branch:master
I think this explicit definition of branches on git push is always
better, unless you are pushing a lot of branches at the same time.
Regards,
Cláudio
On Thu, Jul 19, 2012 at 8:02 AM, Thomas Dörfler
<Thomas.Doerfler at embedded-brains.de> wrote:
> Sebastian,
> if this makes sense, can you add this info to the RTEMS Wiki?
> Thomas.
> On 19.07.2012 08:59, Sebastian Huber wrote:
>> Hi,
>> I think one of the most dangerous default settings in Git is the push
>> strategy:
>> You can specify what action you want to take in this case, and
>> avoid seeing this message again, by configuring 'push.default' to:
>> 'nothing' : Do not push anything
>> 'matching' : Push all matching branches (default)
>> 'tracking' : Push the current branch to whatever it is tracking
>> 'current' : Push the current branch
>> I set it now to 'current'. The mistake from my last week was due to
>> this default push setting. You can always check that you push the right
>> commits with "git status".
>> On 07/18/2012 03:39 PM, Joel Sherrill wrote:
>>> On 07/18/2012 12:50 AM, Thomas Doerfler wrote:
>>>> Joel,
>>>> just a note: These commit messages do not really look useful :-( We had
>>>> that discussion before with different users, so please don't get me
>>>> wrong...
>>> I know. :(
>>> Apparently git generates them when you merge a branch which has
>>> no changes on it. That seems broken to me.
>>> I accidentally was on the wrong branch and couldn't figure out why
>>> my changes (from another temporary branch) weren't showing up
>>> on the master. The temporary branch I was on had no changes
>>> and this is what got generated.
>>> The other cases were stupid user errors. This was also but why
>>> would git generate a message when there was really nothing
>>> to do?
>>> --joel
>>>> wkr,
>>>> Thomas.
>>>> Am 17.07.2012 23:16, schrieb Joel Sherrill:
>>>>> Module: rtems
>>>>> Branch: master
>>>>> Commit: fac44e12519e401415af7989b80f8a80f7b7de0f
>>>>> Changeset:
>>>>> http://git.rtems.org/rtems/commit/?id=fac44e12519e401415af7989b80f8a80f7b7de0f
>>>>> Author: Joel Sherrill<joel.sherrill at oarcorp.com>
>>>>> Date: Mon Jul 9 11:56:40 2012 -0500
>>>>> _______________________________________________
>>>>> rtems-vc mailing list
>>>>> rtems-vc at rtems.org
>>>>> http://www.rtems.org/mailman/listinfo/rtems-vc
> Embedded Brains GmbH
> Thomas Doerfler Obere Lagerstrasse 30
> D-82178 Puchheim Germany
> email: Thomas.Doerfler at embedded-brains.de
> Phone: +49-89-18908079-2
> Fax: +49-89-18908079-9
> rtems-devel mailing list
> rtems-devel at rtems.org
