[GSOC] Docs(Xiaochen Pan)
Ashi
ashi08104 at gmail.com
Wed Jul 25 12:13:51 UTC 2012
2012/7/25 Xiaochen Pan <panx at seas.upenn.edu>
> Hi,
> I downloaded two documentation from the web, the classic API docs and
> posix API docs.
> http://www.rtems.com/onlinedocs/releases/rtemsdocs-4.6.99.3/share/rtems/html/index.html
> It is noted to be the RTEMS 4.6.99.3 version docs. Is it outdated? Are
> there modifications to the managers and directives for each manager?
Hi, xiaochen, your version of docs is a little old, as I know the recent
doc version is 4.10.2:
http://www.rtems.org/onlinedocs/releases/rtemsdocs-4.10.2/share/rtems/html/
and there is also a daily build version:
http://rtems.org/onlinedocs/doc-current/share/rtems/html/
> What is the structure for RTEMS executive core, which includes the CPU
> dependent routines?
If you mean the directory structure of RTEMS, here is a general discription:
http://www.rtems.org/onlinedocs/releases/rtemsdocs-4.10.2/share/rtems/html/develenv/develenv00002.html
> xiaochen Pan
> rtems-devel mailing list
> rtems-devel at rtems.org
Best wishes!
Zhongwei Yao
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120725/b4312942/attachment-0001.html>
