[PATCH] m68k: Fix interrupt stack switch
Fri Jun 1 14:09:21 UTC 2012
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
The previous code compared
&_Per_CPU_Information [0].interrupt_stack_low
with the current stack pointer (register a7). Instead it must compare
the value
with the current stack pointer.
cpukit/score/cpu/m68k/cpu_asm.S | 4 ++--
1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/cpukit/score/cpu/m68k/cpu_asm.S b/cpukit/score/cpu/m68k/cpu_asm.S
index f68cb10..f8852e4 100644
--- a/cpukit/score/cpu/m68k/cpu_asm.S
+++ b/cpukit/score/cpu/m68k/cpu_asm.S
@@ -260,9 +260,9 @@ SYM (_ISR_Handler):
#if ( CPU_HAS_SOFTWARE_INTERRUPT_STACK == 1 )
- | Make a0 point just above interrupt stack
+ movel INTERRUPT_STACK_LOW,a1
movel INTERRUPT_STACK_HIGH,a0
- cmpl INTERRUPT_STACK_LOW,a7 | stack below interrupt stack?
+ cmpl a1,a7 | stack below interrupt stack?
bcs.b 1f | yes, switch to interrupt stack
cmpl a0,a7 | stack above interrupt stack?
bcs.b 2f | no, do not switch stacks
1.7.1
