[PATCH] libblock: Add device statistics
Mon Jun 4 15:34:56 UTC 2012
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
diff --git a/cpukit/libblock/Makefile.am b/cpukit/libblock/Makefile.am
index 6ddc524..bdc181e 100644
--- a/cpukit/libblock/Makefile.am
+++ b/cpukit/libblock/Makefile.am
@@ -7,6 +7,7 @@ libblock_a_SOURCES = src/bdbuf.c \
src/blkdev-imfs.c \
src/blkdev-ioctl.c \
src/blkdev-ops.c \
+ src/blkdev-print-stats.c \
src/diskdevs.c \
src/diskdevs-init.c \
src/flashdisk.c \
diff --git a/cpukit/libblock/include/rtems/bdbuf.h b/cpukit/libblock/include/rtems/bdbuf.h
index 5275c13..6c6eb76 100644
--- a/cpukit/libblock/include/rtems/bdbuf.h
+++ b/cpukit/libblock/include/rtems/bdbuf.h
@@ -318,7 +318,7 @@ typedef struct rtems_bdbuf_buffer
signed char bal; /**< The balance of the sub-tree */
} avl;
- const rtems_disk_device *dd; /**< disk device */
+ rtems_disk_device *dd; /**< disk device */
rtems_blkdev_bnum block; /**< block number on the device */
@@ -662,6 +662,19 @@ rtems_bdbuf_purge_dev (rtems_disk_device *dd);
rtems_status_code
rtems_bdbuf_set_block_size (rtems_disk_device *dd, uint32_t block_size);
+ * @brief Returns the block device statistics.
+void
+rtems_bdbuf_get_device_stats (const rtems_disk_device *dd,
+ rtems_blkdev_stats *stats);
+ * @brief Resets the block device statistics.
+void
+rtems_bdbuf_reset_device_stats (rtems_disk_device *dd);
#ifdef __cplusplus
diff --git a/cpukit/libblock/include/rtems/blkdev.h b/cpukit/libblock/include/rtems/blkdev.h
index 7c27872..84c5586 100644
--- a/cpukit/libblock/include/rtems/blkdev.h
+++ b/cpukit/libblock/include/rtems/blkdev.h
@@ -16,6 +16,7 @@
#include <rtems/diskdevs.h>
+#include <rtems/bspIo.h>
#include <sys/ioctl.h>
#ifdef __cplusplus
@@ -161,6 +162,8 @@ typedef struct rtems_blkdev_request {
#define RTEMS_BLKIO_CAPABILITIES _IO('B', 8)
#define RTEMS_BLKIO_GETDISKDEV _IOR('B', 9, rtems_disk_device *)
#define RTEMS_BLKIO_PURGEDEV _IO('B', 10)
+#define RTEMS_BLKIO_GETDEVSTATS _IOR('B', 11, rtems_blkdev_stats *)
+#define RTEMS_BLKIO_RESETDEVSTATS _IO('B', 12)
@@ -208,6 +211,19 @@ static inline int rtems_disk_fd_purge(int fd)
return ioctl(fd, RTEMS_BLKIO_PURGEDEV);
+static inline int rtems_disk_fd_get_device_stats(
+ int fd,
+ return ioctl(fd, RTEMS_BLKIO_GETDEVSTATS, stats);
+static inline int rtems_disk_fd_reset_device_stats(int fd)
+ return ioctl(fd, RTEMS_BLKIO_RESETDEVSTATS);
* Only consecutive multi-sector buffer requests are supported.
@@ -361,6 +377,15 @@ rtems_status_code rtems_blkdev_create_partition(
rtems_blkdev_bnum block_count
+ * @brief Prints the block device statistics to the file.
+void rtems_blkdev_print_stats(
+ const rtems_blkdev_stats *stats,
+ rtems_printk_plugin_t print,
+ void *print_arg
#ifdef __cplusplus
diff --git a/cpukit/libblock/include/rtems/diskdevs.h b/cpukit/libblock/include/rtems/diskdevs.h
index 6e6be5e..3a9967e 100644
--- a/cpukit/libblock/include/rtems/diskdevs.h
+++ b/cpukit/libblock/include/rtems/diskdevs.h
@@ -87,6 +87,68 @@ typedef struct {
} rtems_blkdev_read_ahead;
+ * @brief Block device statistics.
+ * Integer overflows in the statistic counters may happen.
+typedef struct {
+ * @brief Read hit count.
+ * A read hit occurs in the rtems_bdbuf_read() function in case the block is
+ * in the cached or modified state.
+ uint32_t read_hits;
+ * @brief Read miss count.
+ * A read miss occurs in the rtems_bdbuf_read() function in case the block is
+ * in the empty state and a read transfer must be initiated to read the data
+ * from the device.
+ uint32_t read_misses;
+ * @brief Read-ahead transfer count.
+ * Each read-ahead transfer may read multiple blocks.
+ uint32_t read_ahead_transfers;
+ * @brief Count of blocks transfered from the device.
+ uint32_t read_blocks;
+ * @brief Read error count.
+ * Error count of transfers issued by the read or read-ahead requests.
+ uint32_t read_errors;
+ * @brief Write transfer count.
+ * Each write transfer may write multiple blocks.
+ uint32_t write_transfers;
+ * @brief Count of blocks transfered to the device.
+ uint32_t write_blocks;
+ * @brief Write error count.
+ * Error count of transfers issued by write requests.
+ uint32_t write_errors;
+} rtems_blkdev_stats;
* @brief Description of a disk device (logical and physical disks).
* An array of pointer tables to rtems_disk_device structures is maintained.
@@ -202,6 +264,11 @@ struct rtems_disk_device {
bool deleted;
+ * @brief Device statistics for this disk.
+ rtems_blkdev_stats stats;
* @brief Read-ahead control for this disk.
rtems_blkdev_read_ahead read_ahead;
diff --git a/cpukit/libblock/src/bdbuf.c b/cpukit/libblock/src/bdbuf.c
index 424b9a3..81c8b81 100644
--- a/cpukit/libblock/src/bdbuf.c
+++ b/cpukit/libblock/src/bdbuf.c
@@ -58,7 +58,7 @@
typedef struct rtems_bdbuf_swapout_transfer
rtems_chain_control bds; /**< The transfer list of BDs. */
- const rtems_disk_device *dd; /**< The device the transfer is for. */
+ rtems_disk_device *dd; /**< The device the transfer is for. */
bool syncing; /**< The data is a sync'ing. */
rtems_blkdev_request* write_req; /**< The write request array. */
uint32_t bufs_per_bd; /**< Number of buffers per bd. */
@@ -113,7 +113,7 @@ typedef struct rtems_bdbuf_cache
rtems_id sync_lock; /**< Sync calls block writes. */
bool sync_active; /**< True if a sync is active. */
rtems_id sync_requester; /**< The sync requester. */
- const rtems_disk_device *sync_device; /**< The device to sync and
+ rtems_disk_device *sync_device; /**< The device to sync and
* BDBUF_INVALID_DEV not a device
* sync. */
@@ -1223,7 +1223,7 @@ rtems_bdbuf_group_realloc (rtems_bdbuf_group* group, size_t new_bds_per_group)
static void
rtems_bdbuf_setup_empty_buffer (rtems_bdbuf_buffer *bd,
- const rtems_disk_device *dd,
+ rtems_disk_device *dd,
rtems_blkdev_bnum block)
bd->dd = dd ;
@@ -1239,8 +1239,8 @@ rtems_bdbuf_setup_empty_buffer (rtems_bdbuf_buffer *bd,
static rtems_bdbuf_buffer *
-rtems_bdbuf_get_buffer_from_lru_list (const rtems_disk_device *dd,
- rtems_blkdev_bnum block)
+rtems_bdbuf_get_buffer_from_lru_list (rtems_disk_device *dd,
+ rtems_blkdev_bnum block)
rtems_chain_node *node = rtems_chain_first (&bdbuf_cache.lru);
@@ -1707,8 +1707,8 @@ rtems_bdbuf_sync_after_access (rtems_bdbuf_buffer *bd)
-rtems_bdbuf_get_buffer_for_read_ahead (const rtems_disk_device *dd,
+rtems_bdbuf_get_buffer_for_read_ahead (rtems_disk_device *dd,
rtems_bdbuf_buffer *bd = NULL;
@@ -1732,8 +1732,8 @@ rtems_bdbuf_get_buffer_for_read_ahead (const rtems_disk_device *dd,
-rtems_bdbuf_get_buffer_for_access (const rtems_disk_device *dd,
+rtems_bdbuf_get_buffer_for_access (rtems_disk_device *dd,
@@ -1874,9 +1874,9 @@ rtems_bdbuf_transfer_done (void* arg, rtems_status_code status)
static rtems_status_code
-rtems_bdbuf_execute_transfer_request (const rtems_disk_device *dd,
- rtems_blkdev_request *req,
- bool cache_locked)
+rtems_bdbuf_execute_transfer_request (rtems_disk_device *dd,
+ rtems_blkdev_request *req,
+ bool cache_locked)
rtems_status_code sc = RTEMS_SUCCESSFUL;
int result = 0;
@@ -1899,6 +1899,21 @@ rtems_bdbuf_execute_transfer_request (const rtems_disk_device *dd,
rtems_bdbuf_lock_cache ();
+ /* Statistics */
+ if (req->req == RTEMS_BLKDEV_REQ_READ)
+ dd->stats.read_blocks += req->bufnum;
+ if (sc != RTEMS_SUCCESSFUL)
+ ++dd->stats.read_errors;
+ else
+ dd->stats.write_blocks += req->bufnum;
+ ++dd->stats.write_transfers;
+ ++dd->stats.write_errors;
for (transfer_index = 0; transfer_index < req->bufnum; ++transfer_index)
rtems_bdbuf_buffer *bd = req->bufs [transfer_index].user;
@@ -1936,9 +1951,9 @@ rtems_bdbuf_execute_transfer_request (const rtems_disk_device *dd,
-rtems_bdbuf_execute_read_request (const rtems_disk_device *dd,
- rtems_bdbuf_buffer *bd,
- uint32_t transfer_count)
+rtems_bdbuf_execute_read_request (rtems_disk_device *dd,
+ rtems_bdbuf_buffer *bd,
+ uint32_t transfer_count)
rtems_blkdev_request *req = NULL;
rtems_blkdev_bnum media_block = bd->block;
@@ -2074,12 +2089,15 @@ rtems_bdbuf_read (rtems_disk_device *dd,
switch (bd->state)
case RTEMS_BDBUF_STATE_CACHED:
+ ++dd->stats.read_hits;
rtems_bdbuf_set_state (bd, RTEMS_BDBUF_STATE_ACCESS_CACHED);
break;
case RTEMS_BDBUF_STATE_MODIFIED:
rtems_bdbuf_set_state (bd, RTEMS_BDBUF_STATE_ACCESS_MODIFIED);
break;
case RTEMS_BDBUF_STATE_EMPTY:
+ ++dd->stats.read_misses;
rtems_bdbuf_set_read_ahead_trigger (dd, block);
sc = rtems_bdbuf_execute_read_request (dd, bd, 1);
if (sc == RTEMS_SUCCESSFUL)
@@ -2285,7 +2303,7 @@ rtems_bdbuf_swapout_write (rtems_bdbuf_swapout_transfer* transfer)
uint32_t bufs_per_bd = 0;
- const rtems_disk_device *dd = transfer->dd;
+ rtems_disk_device *dd = transfer->dd;
bufs_per_bd = dd->block_size / bdbuf_config.buffer_min;
@@ -2384,7 +2402,7 @@ rtems_bdbuf_swapout_write (rtems_bdbuf_swapout_transfer* transfer)
* amount.
static void
-rtems_bdbuf_swapout_modified_processing (const rtems_disk_device **dd_ptr,
+rtems_bdbuf_swapout_modified_processing (rtems_disk_device **dd_ptr,
rtems_chain_control* chain,
rtems_chain_control* transfer,
bool sync_active,
@@ -3025,6 +3043,7 @@ rtems_bdbuf_read_ahead_task (rtems_task_argument arg)
dd->read_ahead.trigger = RTEMS_DISK_READ_AHEAD_NO_TRIGGER;
+ ++dd->stats.read_ahead_transfers;
rtems_bdbuf_execute_read_request (dd, bd, transfer_count);
@@ -3039,3 +3058,18 @@ rtems_bdbuf_read_ahead_task (rtems_task_argument arg)
rtems_task_delete (RTEMS_SELF);
+void rtems_bdbuf_get_device_stats (const rtems_disk_device *dd,
+ rtems_bdbuf_lock_cache ();
+ *stats = dd->stats;
+ rtems_bdbuf_unlock_cache ();
+void rtems_bdbuf_reset_device_stats (rtems_disk_device *dd)
+ memset (&dd->stats, 0, sizeof(dd->stats));
diff --git a/cpukit/libblock/src/blkdev-ioctl.c b/cpukit/libblock/src/blkdev-ioctl.c
index d775d1e..b2215f1 100644
--- a/cpukit/libblock/src/blkdev-ioctl.c
+++ b/cpukit/libblock/src/blkdev-ioctl.c
@@ -64,6 +64,14 @@ rtems_blkdev_ioctl(rtems_disk_device *dd, uint32_t req, void *argp)
rtems_bdbuf_purge_dev(dd);
break;
+ case RTEMS_BLKIO_GETDEVSTATS:
+ rtems_bdbuf_get_device_stats(dd, (rtems_blkdev_stats *) argp);
+ break;
+ case RTEMS_BLKIO_RESETDEVSTATS:
+ rtems_bdbuf_reset_device_stats(dd);
+ break;
default:
errno = EINVAL;
rc = -1;
diff --git a/cpukit/libblock/src/blkdev-print-stats.c b/cpukit/libblock/src/blkdev-print-stats.c
new file mode 100644
index 0000000..8cebeaf
--- /dev/null
+++ b/cpukit/libblock/src/blkdev-print-stats.c
@@ -0,0 +1,52 @@
+ * Copyright (c) 2012 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Obere Lagerstr. 30
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#if HAVE_CONFIG_H
+ #include "config.h"
+#endif
+#include <rtems/blkdev.h>
+#include <inttypes.h>
+ void *print_arg
+ (*print)(
+ print_arg,
+ "-------------------------------------------------------------------------------\n"
+ " DEVICE STATISTICS\n"
+ "----------------------+--------------------------------------------------------\n"
+ " READ HITS | %" PRIu32 "\n"
+ " READ MISSES | %" PRIu32 "\n"
+ " READ AHEAD TRANSFERS | %" PRIu32 "\n"
+ " READ BLOCKS | %" PRIu32 "\n"
+ " READ ERRORS | %" PRIu32 "\n"
+ " WRITE TRANSFERS | %" PRIu32 "\n"
+ " WRITE BLOCKS | %" PRIu32 "\n"
+ " WRITE ERRORS | %" PRIu32 "\n"
+ "----------------------+--------------------------------------------------------\n",
+ stats->read_hits,
+ stats->read_misses,
+ stats->read_ahead_transfers,
+ stats->read_blocks,
+ stats->read_errors,
+ stats->write_transfers,
+ stats->write_blocks,
+ stats->write_errors
diff --git a/cpukit/libmisc/Makefile.am b/cpukit/libmisc/Makefile.am
index 654c050..b0b2195 100644
--- a/cpukit/libmisc/Makefile.am
+++ b/cpukit/libmisc/Makefile.am
@@ -104,6 +104,7 @@ libshell_a_SOURCES = shell/cat_file.c shell/cmds.c shell/internal.h \
shell/main_setenv.c shell/main_getenv.c shell/main_unsetenv.c \
shell/main_mkrfs.c shell/main_debugrfs.c \
shell/main_lsof.c \
+ shell/main_blkstats.c \
shell/shell-wait-for-input.c
if LIBNETWORKING
diff --git a/cpukit/libmisc/shell/main_blkstats.c b/cpukit/libmisc/shell/main_blkstats.c
index 0000000..6d28f95
--- /dev/null
+++ b/cpukit/libmisc/shell/main_blkstats.c
@@ -0,0 +1,99 @@
+ * 82178 Puchheim
+ * Germany
+#if HAVE_CONFIG_H
+#endif
+#include <rtems/shell.h>
+#include <rtems/shellconfig.h>
+#include <sys/stat.h>
+#include <fcntl.h>
+#include <stdio.h>
+#include <unistd.h>
+#include <errno.h>
+static void blkstats(const char *device, bool reset)
+ int fd = open(device, O_RDONLY);
+ if (fd >= 0) {
+ int rv;
+ if (reset) {
+ rv = rtems_disk_fd_reset_device_stats(fd);
+ if (rv != 0) {
+ fprintf(stdout, "error: cannot reset stats: %s\n", strerror(errno));
+ } else {
+ rv = rtems_disk_fd_get_device_stats(fd, &stats);
+ if (rv == 0) {
+ rtems_blkdev_print_stats(
+ &stats,
+ (rtems_printk_plugin_t) fprintf,
+ stdout
+ } else {
+ fprintf(stdout, "error: get stats: %s\n", strerror(errno));
+ rv = close(fd);
+ if (rv != 0) {
+ fprintf(stdout, "error: close device: %s\n", strerror(errno));
+ } else {
+ fprintf(stdout, "error: cannot open device: %s\n", strerror(errno));
+static bool is_reset_option(const char *opt)
+ return strcmp(opt, "-r") == 0 || strcmp(opt, "--reset") == 0;
+static int rtems_shell_main_blkstats(int argc, char **argv)
+ bool ok = false;
+ bool reset = false;
+ const char *device;
+ if (argc == 2) {
+ ok = true;
+ device = argv [1];
+ } else if (argc == 3 && is_reset_option(argv [1])) {
+ ok = true;
+ reset = true;
+ device = argv [2];
+ if (ok) {
+ blkstats(device, reset);
+ } else {
+ fprintf(stdout, "usage: %s\n", rtems_shell_BLKSTATS_Command.usage);
+ return 0;
+rtems_shell_cmd_t rtems_shell_BLKSTATS_Command = {
+ .name = "blkstats",
+ .usage = "blkstats [-r|--reset] PATH_TO_DEVICE",
+ .topic = "files",
+ .command = rtems_shell_main_blkstats
diff --git a/cpukit/libmisc/shell/shellconfig.h b/cpukit/libmisc/shell/shellconfig.h
index 85fb3d0..9f45151 100644
--- a/cpukit/libmisc/shell/shellconfig.h
+++ b/cpukit/libmisc/shell/shellconfig.h
@@ -65,6 +65,7 @@ extern rtems_shell_cmd_t rtems_shell_LSOF_Command;
extern rtems_shell_cmd_t rtems_shell_MOUNT_Command;
extern rtems_shell_cmd_t rtems_shell_UNMOUNT_Command;
extern rtems_shell_cmd_t rtems_shell_BLKSYNC_Command;
+extern rtems_shell_cmd_t rtems_shell_BLKSTATS_Command;
extern rtems_shell_cmd_t rtems_shell_FDISK_Command;
extern rtems_shell_cmd_t rtems_shell_DD_Command;
extern rtems_shell_cmd_t rtems_shell_HEXDUMP_Command;
@@ -350,6 +351,11 @@ extern rtems_shell_alias_t *rtems_shell_Initial_aliases[];
&rtems_shell_BLKSYNC_Command,
#endif
#if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
+ !defined(CONFIGURE_SHELL_NO_COMMAND_BLKSTATS)) || \
+ defined(CONFIGURE_SHELL_COMMAND_BLKSTATS)
+ &rtems_shell_BLKSTATS_Command,
+ #endif
+ #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
!defined(CONFIGURE_SHELL_NO_COMMAND_FDISK)) || \
defined(CONFIGURE_SHELL_COMMAND_FDISK)
&rtems_shell_FDISK_Command,
diff --git a/testsuites/libtests/Makefile.am b/testsuites/libtests/Makefile.am
index 9747ad1..6a0d20f 100644
--- a/testsuites/libtests/Makefile.am
+++ b/testsuites/libtests/Makefile.am
@@ -1,6 +1,7 @@
ACLOCAL_AMFLAGS = -I ../aclocal
SUBDIRS = POSIX
+SUBDIRS += block14
SUBDIRS += block13
SUBDIRS += rbheap01
SUBDIRS += flashdisk01
diff --git a/testsuites/libtests/block14/Makefile.am b/testsuites/libtests/block14/Makefile.am
index 0000000..a7769de
--- /dev/null
+++ b/testsuites/libtests/block14/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = block14
+block14_SOURCES = init.c
+dist_rtems_tests_DATA = block14.scn block14.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(block14_OBJECTS)
+LINK_LIBS = $(block14_LDLIBS)
+block14$(EXEEXT): $(block14_OBJECTS) $(block14_DEPENDENCIES)
+ @rm -f block14$(EXEEXT)
+ $(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/libtests/block14/block14.doc b/testsuites/libtests/block14/block14.doc
index 0000000..de5bc68
--- /dev/null
+++ b/testsuites/libtests/block14/block14.doc
@@ -0,0 +1,11 @@
+This file describes the directives and concepts tested by this test set.
+test set name: block14
+directives:
+ TBD
+concepts:
+ Ensure that the block device statistics work.
diff --git a/testsuites/libtests/block14/block14.scn b/testsuites/libtests/block14/block14.scn
index 0000000..009ebb0
--- /dev/null
+++ b/testsuites/libtests/block14/block14.scn
@@ -0,0 +1,21 @@
+*** TEST BLOCK 14 ***
+action 0
+action 1
+action 2
+action 3
+action 4
+action 5
+action 6
+ DEVICE STATISTICS
+ READ HITS | 2
+ READ MISSES | 3
+ READ AHEAD TRANSFERS | 2
+ READ BLOCKS | 5
+ READ ERRORS | 1
+ WRITE TRANSFERS | 2
+ WRITE BLOCKS | 2
+ WRITE ERRORS | 1
+*** END OF TEST BLOCK 14 ***
diff --git a/testsuites/libtests/block14/init.c b/testsuites/libtests/block14/init.c
index 0000000..b95b86d
--- /dev/null
+++ b/testsuites/libtests/block14/init.c
@@ -0,0 +1,222 @@
+ * 82178 Puchheim
+ * Germany
+#ifdef HAVE_CONFIG_H
+#endif
+#include "tmacros.h"
+#include <errno.h>
+#include <string.h>
+#include <rtems/bdbuf.h>
+#define ACTION_COUNT 7
+#define BLOCK_COUNT 6
+typedef struct {
+ rtems_blkdev_bnum block;
+ rtems_status_code (*get)(
+ rtems_blkdev_bnum block,
+ rtems_bdbuf_buffer **bd_ptr
+ rtems_status_code expected_get_status;
+ rtems_status_code (*release)(rtems_bdbuf_buffer *bd);
+} test_action;
+static const test_action actions [ACTION_COUNT] = {
+ { 0, rtems_bdbuf_read, RTEMS_SUCCESSFUL, rtems_bdbuf_release },
+ { 1, rtems_bdbuf_read, RTEMS_SUCCESSFUL, rtems_bdbuf_release },
+ { 2, rtems_bdbuf_read, RTEMS_SUCCESSFUL, rtems_bdbuf_release },
+ { 4, rtems_bdbuf_get, RTEMS_SUCCESSFUL, rtems_bdbuf_sync },
+ { 5, rtems_bdbuf_read, RTEMS_IO_ERROR, rtems_bdbuf_release },
+ { 5, rtems_bdbuf_get, RTEMS_SUCCESSFUL, rtems_bdbuf_sync }
+#define STATS(a, b, c, d, e, f, g, h) \
+ .read_hits = a, \
+ .read_misses = b, \
+ .read_ahead_transfers = c, \
+ .read_blocks = d, \
+ .read_errors = e, \
+ .write_transfers = f, \
+ .write_blocks = g, \
+ .write_errors = h \
+static const rtems_blkdev_stats expected_stats [ACTION_COUNT] = {
+ STATS(0, 1, 0, 1, 0, 0, 0, 0),
+ STATS(0, 2, 1, 3, 0, 0, 0, 0),
+ STATS(1, 2, 2, 4, 0, 0, 0, 0),
+ STATS(2, 2, 2, 4, 0, 0, 0, 0),
+ STATS(2, 2, 2, 4, 0, 1, 1, 0),
+ STATS(2, 3, 2, 5, 1, 1, 1, 0),
+ STATS(2, 3, 2, 5, 1, 2, 2, 1)
+static const int expected_block_access_counts [ACTION_COUNT] [BLOCK_COUNT] = {
+ { 1, 0, 0, 0, 0, 0 },
+ { 1, 1, 1, 0, 0, 0 },
+ { 1, 1, 1, 1, 0, 0 },
+ { 1, 1, 1, 1, 1, 0 },
+ { 1, 1, 1, 1, 1, 1 },
+ { 1, 1, 1, 1, 1, 2 }
+static int block_access_counts [BLOCK_COUNT];
+static int test_disk_ioctl(rtems_disk_device *dd, uint32_t req, void *arg)
+ int rv = 0;
+ if (req == RTEMS_BLKIO_REQUEST) {
+ rtems_status_code sc = RTEMS_SUCCESSFUL;
+ rtems_blkdev_request *breq = arg;
+ rtems_blkdev_sg_buffer *sg = breq->bufs;
+ uint32_t i;
+ for (i = 0; i < breq->bufnum; ++i) {
+ rtems_blkdev_bnum block = sg [i].block;
+ rtems_test_assert(block < BLOCK_COUNT);
+ ++block_access_counts [block];
+ if (block == 5) {
+ sc = RTEMS_IO_ERROR;
+ (*breq->req_done)(breq->done_arg, sc);
+ } else {
+ errno = EINVAL;
+ rv = -1;
+ return rv;
+static void test_actions(rtems_disk_device *dd)
+ int i;
+ for (i = 0; i < ACTION_COUNT; ++i) {
+ const test_action *action = &actions [i];
+ rtems_status_code sc;
+ rtems_bdbuf_buffer *bd;
+ printf("action %i\n", i);
+ sc = (*action->get)(dd, action->block, &bd);
+ rtems_test_assert(sc == action->expected_get_status);
+ if (sc == RTEMS_SUCCESSFUL) {
+ sc = (*action->release)(bd);
+ rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+ memcmp(
+ block_access_counts,
+ expected_block_access_counts [i],
+ sizeof(block_access_counts)
+ ) == 0
+ rtems_bdbuf_get_device_stats(dd, &stats);
+ memcmp(
+ &stats,
+ &expected_stats [i],
+ sizeof(stats)
+ ) == 0
+ rtems_blkdev_print_stats(&dd->stats, rtems_printf_plugin, NULL);
+static void test(void)
+ dev_t dev = 0;
+ sc = rtems_disk_io_initialize();
+ sc = rtems_disk_create_phys(
+ dev,
+ 1,
+ BLOCK_COUNT,
+ test_disk_ioctl,
+ NULL,
+ NULL
+ dd = rtems_disk_obtain(dev);
+ rtems_test_assert(dd != NULL);
+ test_actions(dd);
+ sc = rtems_disk_release(dd);
+ sc = rtems_disk_delete(dev);
+static void Init(rtems_task_argument arg)
+ puts("\n\n*** TEST BLOCK 14 ***");
+ test();
+ puts("*** END OF TEST BLOCK 14 ***");
+ rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
+#define CONFIGURE_BDBUF_BUFFER_MIN_SIZE 1
+#define CONFIGURE_BDBUF_BUFFER_MAX_SIZE 1
+#define CONFIGURE_BDBUF_CACHE_MEMORY_SIZE BLOCK_COUNT
+#define CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS 1
+#define CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY 1
+#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
+#define CONFIGURE_INIT_TASK_PRIORITY 2
+#include <rtems/confdefs.h>
diff --git a/testsuites/libtests/configure.ac b/testsuites/libtests/configure.ac
index 7df0520..f383ac1 100644
--- a/testsuites/libtests/configure.ac
+++ b/testsuites/libtests/configure.ac
@@ -41,6 +41,7 @@ AM_CONDITIONAL(NETTESTS,test "$rtems_cv_RTEMS_NETWORKING" = "yes")
# Explicitly list all Makefiles here
AC_CONFIG_FILES([Makefile
+block14/Makefile
block13/Makefile
rbheap01/Makefile
syscall01/Makefile
