GSoC RTEMS compilation issues
Mon Jun 18 15:31:51 UTC 2012
You might also want to remove the
# clock
libbsp_a_SOURCES += clock/ckinit.c
# console
libbsp_a_SOURCES += console/console.c
# timer
libbsp_a_SOURCES += timer/timer.c timer/timerisr.c
# shmsupp
libbsp_a_SOURCES += shmsupp/addrconv.c shmsupp/getcfg.c shmsupp/lock.c \
    shmsupp/mpisr.c
and add them in one at a time as you get them to work. Have you read
the BSP Howto manual [1]? It is strongly recommended for anyone who
develops a BSP.
[1] http://rtems.org/onlinedocs/doc-current/share/rtems/html/bsp_howto/bsp_howto.html
On Mon, Jun 18, 2012 at 7:57 AM, Julien Delange
<julien.delange at gmail.com> wrote:
> Hi,
> I think you should read [1] even if your description of the
> --enable-maintainer-mode seems correct. About the problem you have, it
> would be great to be able to make a test. so far, I do not see the
> problem just by inspecting the sources and so, it would require more
> investigation.
> So, if you can provide few instructions to get the sources tree with
> your changes, we might also give a try :-)
> Best,
> [1] http://rtemsramblings.blogspot.nl/2012/05/rtems-build-system-ruminations.html
> rtems-devel mailing list
> rtems-devel at rtems.org
