[GSOC] How to fix this path problem?
Tue Jun 19 16:18:00 UTC 2012
Please post how you configured rtems, how you made rtems, and how you
installed rtems. Then how you are attempting to compiler / link your
application. The version (4.6.2) of gcc seems to be a bit old also, so
check that your toolchain is up-to-date.
-Gedare
On Mon, Jun 18, 2012 at 8:39 PM,  <panx at seas.upenn.edu> wrote:
> Hello,
> Here is one error message when I try to cross-compile an application:
> /opt/rtems-4.11/lib/gcc/sparc-rtems4.11/4.6.2/../../../../sparc-rtems4.11/bin/ld:
> cannot open linker script file linkcmds: No such file or directory
> How to add a script file(particular like linkcmds) to the search path?
> Regards,
> xiaochen
> rtems-devel mailing list
> rtems-devel at rtems.org
