[PATCH fix line breaks] pc386/console: alternative framebuffer implementation for cirrus GD5446 QEMU device
Pavel Pisa ppisa4lists at pikron.com
Wed Jun 20 17:52:50 UTC 2012
The driver is compatible with PCI GD5446 provided by QEMU.
QEMU option "-vga cirrus".
Driver locates PCI device and configures it for linear framebuffer
when "/dev/fb0" is open. Default mode and bit depths are
controlled by FB_CIRRUS_DEFAULT_MODE, FB_CIRRUS_DEFAULT_BPP
defines. 32, 24 and 16 bits per pixel with FB_VISUAL_TRUECOLOR
are supported. 8 bit mode is not finished - requires palette support.
To use alternative Cirrus framebuffer, replace line
  libbsp_a_SOURCES += console/fb_vga.c
in
  c/src/lib/libbsp/i386/pc386/Makefile.am b/c/src/lib/libbsp/i386/pc386/Makefile.am
by
  libbsp_a_SOURCES += console/fb_cirrus.c
Signed-off-by: Pavel Pisa <pisa at cmp.felk.cvut.cz>
 c/src/lib/libbsp/i386/pc386/console/fb_cirrus.c    |  713 ++++++++++++++++++++
 .../lib/libbsp/i386/pc386/console/vga_registers.h  |  102 +++
 2 files changed, 815 insertions(+)
 create mode 100644 c/src/lib/libbsp/i386/pc386/console/fb_cirrus.c
 create mode 100644 c/src/lib/libbsp/i386/pc386/console/vga_registers.h
diff --git a/c/src/lib/libbsp/i386/pc386/console/fb_cirrus.c b/c/src/lib/libbsp/i386/pc386/console/fb_cirrus.c
new file mode 100644
index 0000000..f728497
--- /dev/null
+++ b/c/src/lib/libbsp/i386/pc386/console/fb_cirrus.c
@@ -0,0 +1,713 @@
+ * Copyright (c) 2012 - Pavel Pisa ( pisa at cmp.felk.cvut.cz )
+ * MODULE DESCRIPTION:
+ * This module implements FB driver for "Cirrus GD5446" found in Qemu
+ * emulator.
+ * The code is based on fb_vga.c written by
+ *    Copyright (c) 2000  Rosimildo da Silva ( rdasilva at connecttel.com )
+ * and it is inspired by X11 and Linux kernel sources
+#include <stdlib.h>
+#include <stdio.h>
+#include <errno.h>
+#include <sys/types.h>
+#include <pthread.h>
+#include <bsp.h>
+#include <bsp/irq.h>
+#include <rtems/libio.h>
+#include <rtems/pci.h>
+#include <rtems/fb.h>
+#include "vga_registers.h"
+/* these routines are defined in vgainit.c.*/
+extern void ega_hwinit( void );
+extern void ega_hwterm( void );
+/* mutex attribure */
+pthread_mutex_t mutex = PTHREAD_MUTEX_INITIALIZER;
+#define FB_CIRRUS_MAX_CARDS 1
+#define CIRRUS_VENDOR_ID         0x1013
+#define CIRRUS_GD5446_DEVICE_ID  0x00b8
+/* video modes
+     640 x 480
+     800 x 600
+     1024 x 768
+     1280 x 1024
+struct fb_cirrus_modeline {
+  int clock;
+  int hdisplay;
+  int hsync_start;
+  int hsync_end;
+  int htotal;
+  int hskew;
+  int vdisplay;
+  int vsync_start;
+  int vsync_end;
+  int vtotal;
+  int vscan;
+  unsigned int flags;
+struct fb_cirrus_state {
+  int              found;
+  int              pbus;
+  int              pdev;
+  int              pfun;
+  uint32_t         pci_bar[4];
+  struct fb_var_screeninfo fb_var;
+  struct fb_fix_screeninfo fb_fix;
+  void             *mmregs;
+  struct fb_cirrus_modeline *active_mode;
+/*                                1/4bpp   8bpp   15/16bpp  24bpp  32bpp */
+static int fb_cirrus_max_clocks[] = { 135100, 135100,  85500,  85500,      0 };
+static struct fb_cirrus_modeline fb_cirrus_std_modelines[] = {
+  { .clock = 31500,
+    .hdisplay = 640, .hsync_start = 664, .hsync_end = 704, .htotal = 832, .hskew = 0,
+    .vdisplay = 480, .vsync_start = 489, .vsync_end = 492, .vtotal = 520, .vscan = 0,
+    .flags = 0
+  { .clock = 40000,
+    .hdisplay = 800, .hsync_start = 840, .hsync_end = 968, .htotal = 1056, .hskew = 0,
+    .vdisplay = 600, .vsync_start = 601, .vsync_end = 605, .vtotal = 628, .vscan = 0,
+    .flags = 0
+  { .clock = 0,
+#ifndef FB_CIRRUS_DEFAULT_MODE
+/* TUNABLE - until better place is found, the mode is selected there */
+/* index 0 provides 640x480 at 60 Hz, index 1 800x600 at 60 Hz */
+#define FB_CIRRUS_DEFAULT_MODE 0
+#endif
+#ifndef FB_CIRRUS_DEFAULT_BPP
+/* Bits per pixel, 8, 16, 24 and 32 are supported */
+/* 8 bit mode requires palete support which is not finished yet */
+#define FB_CIRRUS_DEFAULT_BPP  24
+#endif
+static struct fb_cirrus_state fb_cirrus[FB_CIRRUS_MAX_CARDS];
+static int
+fb_cirrus_read_config_dword(
+  struct fb_cirrus_state *fbst,
+  unsigned char where,
+  uint32_t     *pval)
+  return pci_read_config_dword(
+    fbst->pbus, fbst->pdev, fbst->pfun,
+    where, pval);
+static int
+fb_cirrus_write_config_dword(
+  uint32_t     val)
+  return pci_write_config_dword(
+    where, val);
+static void
+fb_cirrus_write_reg8 (
+  const struct fb_cirrus_state *fbst,
+  unsigned int reg,
+  unsigned int val)
+  *(volatile uint8_t*)((char *)fbst->mmregs + reg) = val;
+static void
+fb_cirrus_write_reg32 (
+  unsigned int reg,
+  uint32_t val)
+  *(volatile uint32_t*)((char *)fbst->mmregs + reg) = val;
+static unsigned int
+fb_cirrus_read_reg8 (
+  unsigned int reg)
+  return *(volatile uint8_t*)((char *)fbst->mmregs + reg);
+static uint32_t
+fb_cirrus_read_reg32 (
+  unsigned int reg)
+  return *(volatile uint32_t*)((char *)fbst->mmregs + reg);
+#define SEQ_INDEX 4
+#define SEQ_DATA 5
+static void
+fb_cirrus_write_seq_reg (
+  unsigned int reg,
+  unsigned int val)
+  fb_cirrus_write_reg8(fbst, SEQ_INDEX, reg);
+  fb_cirrus_write_reg8(fbst, SEQ_DATA, val);
+#define CRT_INDEX 0x14
+#define CRT_DATA 0x15
+static void
+fb_cirrus_write_crt_reg (
+  unsigned int reg,
+  unsigned int val)
+  fb_cirrus_write_reg8(fbst, CRT_INDEX, reg);
+  fb_cirrus_write_reg8(fbst, CRT_DATA, val);
+#define GDC_INDEX 0xe
+#define GDC_DATA 0xf
+static void
+fb_cirrus_write_gdc_reg (
+  unsigned int reg,
+  unsigned int val)
+  fb_cirrus_write_reg8(fbst, GDC_INDEX, reg);
+  fb_cirrus_write_reg8(fbst, GDC_DATA, val);
+#define VGA_DAC_MASK 0x6
+static void
+fb_cirrus_write_hdr_reg (
+  unsigned int val)
+  volatile unsigned int dummy __attribute__((unused));
+  dummy = fb_cirrus_read_reg8(fbst, VGA_DAC_MASK);
+  fb_cirrus_write_reg8(fbst, VGA_DAC_MASK, val);
+static void
+fb_cirrus_set_start_address(
+  unsigned offset)
+  uint32_t addr;
+  uint8_t tmp;
+  addr = offset >> 2;
+  fb_cirrus_write_crt_reg(fbst, 0x0c, (uint8_t)((addr >> 8) & 0xff));
+  fb_cirrus_write_crt_reg(fbst, 0x0d, (uint8_t)(addr & 0xff));
+  fb_cirrus_write_reg8(fbst, CRT_INDEX, 0x1b);
+  tmp = fb_cirrus_read_reg8(fbst, CRT_DATA);
+  tmp &= 0xf2;
+  tmp |= (addr >> 16) & 0x01;
+  tmp |= (addr >> 15) & 0x0c;
+  fb_cirrus_write_crt_reg(fbst, 0x1b, tmp);
+  fb_cirrus_write_reg8(fbst, CRT_INDEX, 0x1d);
+  tmp &= 0x7f;
+  tmp |= (addr >> 12) & 0x80;
+  fb_cirrus_write_crt_reg(fbst, 0x1d, tmp);
+static int
+fb_cirrus_set_crt_mode(
+  struct fb_cirrus_modeline *mode)
+  int hsyncstart, hsyncend, htotal, hdispend;
+  int vtotal, vdispend;
+  int tmp;
+  int sr07 = 0, hdr = 0;
+  int x, y;
+  htotal = mode->htotal / 8;
+  hsyncend = mode->hsync_end / 8;
+  hsyncstart = mode->hsync_start / 8;
+  hdispend = mode->hdisplay / 8;
+  vtotal = mode->vtotal;
+  vdispend = mode->vdisplay;
+  vdispend -= 1;
+  vtotal -= 2;
+  htotal -= 5;
+  hdispend -= 1;
+  hsyncstart += 1;
+  hsyncend += 1;
+  fb_cirrus_write_crt_reg(fbst, CRTC_EndVertRetrace, 0x20);
+  fb_cirrus_write_crt_reg(fbst, CRTC_HorzTotal, htotal);
+  fb_cirrus_write_crt_reg(fbst, CRTC_HorzDispEnd, hdispend);
+  fb_cirrus_write_crt_reg(fbst, CRTC_StartHorzRetrace, hsyncstart);
+  fb_cirrus_write_crt_reg(fbst, CRTC_EndHorzRetrace, hsyncend);
+  fb_cirrus_write_crt_reg(fbst, CRTC_VertTotal, vtotal & 0xff);
+  fb_cirrus_write_crt_reg(fbst, CRTC_VertDispEnd, vdispend & 0xff);
+  tmp = 0x40;
+  if ((vdispend + 1) & 512)
+    tmp |= 0x20;
+  fb_cirrus_write_crt_reg(fbst, CRTC_MaxScanLine, tmp);
+  tmp = 16;
+  if (vtotal & 256)
+    tmp |= 1;
+  if (vdispend & 256)
+    tmp |= 2;
+  if ((vdispend + 1) & 256)
+    tmp |= 8;
+  if (vtotal & 512)
+    tmp |= 32;
+  if (vdispend & 512)
+    tmp |= 64;
+  fb_cirrus_write_crt_reg(fbst, CRTC_Overflow, tmp);
+  tmp = 0;
+  if ((htotal + 5) & 64)
+    tmp |= 16;
+  if ((htotal + 5) & 128)
+    tmp |= 32;
+  if (vtotal & 256)
+    tmp |= 64;
+  if (vtotal & 512)
+    tmp |= 128;
+  fb_cirrus_write_crt_reg(fbst, 0x1A, tmp);
+  /* Disable Hercules/CGA compatibility */
+  fb_cirrus_write_crt_reg(fbst, CRTC_ModeCtrl, 0x03);
+  fb_cirrus_write_reg8(fbst, SEQ_INDEX, 0x7);
+  sr07 = fb_cirrus_read_reg8(fbst, SEQ_DATA);
+  sr07 &= 0xe0;
+  hdr = 0;
+  switch (fbst->fb_var.bits_per_pixel) {
+    case 8:
+      sr07 |= 0x11;
+      break;
+    case 16:
+      sr07 |= 0xc7; /* has been 0xc1 */
+      hdr = 0xc0;
+      break;
+    case 24:
+      sr07 |= 0x15;
+      hdr = 0xc5;
+      break;
+    case 32:
+      sr07 |= 0x19;
+      hdr = 0xc5;
+      break;
+    default:
+       printk("FBCIRRUS fb_cirrus_set_crt_mode unsuported BPP\n");
+      return -1;
+  fb_cirrus_write_seq_reg(fbst, 0x7, sr07);
+  /* Program the pitch */
+  tmp = fbst->fb_fix.line_length / 8;
+  fb_cirrus_write_crt_reg(fbst, CRTC_Offset, tmp);
+  /* Enable extended blanking and pitch bits, and enable full memory */
+  tmp = 0x22;
+  tmp |= (fbst->fb_fix.line_length >> 7) & 0x10;
+  tmp |= (fbst->fb_fix.line_length >> 6) & 0x40;
+  /* Enable high-colour modes */
+  fb_cirrus_write_gdc_reg(fbst, GDC_Mode, 0x40);
+  /* And set graphics mode */
+  fb_cirrus_write_gdc_reg(fbst, GDC_Misc, 0x01);
+  fb_cirrus_write_hdr_reg(fbst, hdr);
+  fb_cirrus_set_start_address(fbst, 0);
+  if (1) {
+    uint32_t pixmask;
+    if(fbst->fb_var.bits_per_pixel == 32)
+      pixmask = 0xffffff;
+    else
+      pixmask = (1 << fbst->fb_var.bits_per_pixel) - 1;
+    printk("FBCIRRUS mode set, test patter output\n");
+    /*while(1)*/
+    for(y = 0; y < fbst->fb_var.yres; y++) {
+      for(x = 0; x < fbst->fb_var.xres; x++) {
+        uint32_t color;
+        char *addr = (char *)fbst->fb_fix.smem_start;
+        addr += y * fbst->fb_fix.line_length;
+        addr += x * fbst->fb_var.bits_per_pixel / 8;
+        color = x & 1 ? 0 : y & 1 ? pixmask & 0x000ff00f : pixmask;
+        if(y == fbst->fb_var.yres - 1) {
+          if((x > 0) && (x < fbst->fb_var.xres-1))
+            color = pixmask & 0x00555555;
+          case 8:  *(volatile uint8_t*) addr = color;
+                   break;
+          case 16: *(volatile uint16_t*) addr = color;
+                   break;
+          case 24: *(volatile uint32_t*) addr =
+                   (*(volatile uint32_t*) addr & 0xff000000) | color;
+                   break;
+         case 32: *(volatile uint32_t*) addr = color;
+                   break;
+  return 0;
+static uint16_t red16[] = {
+   0x0000, 0x0000, 0x0000, 0x0000, 0xaaaa, 0xaaaa, 0xaaaa, 0xaaaa,
+   0x5555, 0x5555, 0x5555, 0x5555, 0xffff, 0xffff, 0xffff, 0xffff
+static uint16_t green16[] = {
+   0x0000, 0x0000, 0xaaaa, 0xaaaa, 0x0000, 0x0000, 0x5555, 0xaaaa,
+   0x5555, 0x5555, 0xffff, 0xffff, 0x5555, 0x5555, 0xffff, 0xffff
+static uint16_t blue16[] = {
+   0x0000, 0xaaaa, 0x0000, 0xaaaa, 0x0000, 0xaaaa, 0x0000, 0xaaaa,
+   0x5555, 0xffff, 0x5555, 0xffff, 0x5555, 0xffff, 0x5555, 0xffff
+/* Functionality to support multiple VGA frame buffers can be added easily,
+ * but is not supported at this moment because there is no need for two or
+ * more "classic" VGA adapters.  Multiple frame buffer drivers may be
+ * implemented and If we had implement it they would be named as "/dev/fb0",
+ * "/dev/fb1", "/dev/fb2" and so on.
+ * fbvga device driver INITIALIZE entry point.
+rtems_device_driver frame_buffer_initialize(
+  rtems_device_major_number  major,
+  rtems_device_minor_number  minor,
+  void                      *arg
+  rtems_status_code status;
+  int res;
+  struct fb_cirrus_state *fbst;
+  char devname[12];
+  char *p;
+  if(minor >= FB_CIRRUS_MAX_CARDS) {
+    printk( "FBCIRRUS initialize -- unsupported minor\n" );
+    return RTEMS_UNSATISFIED;
+  fbst = &fb_cirrus[minor];
+  res = pci_find_device(
+    CIRRUS_VENDOR_ID,
+    CIRRUS_GD5446_DEVICE_ID,
+    minor,
+    &fbst->pbus,
+    &fbst->pdev,
+    &fbst->pfun
+  if ( res != PCIB_ERR_SUCCESS ) {
+    fbst->found = -1;
+    printk( "FBCIRRUS initialize -- device not found\n" );
+  printk( "FBCIRRUS -- driver initializing..\n" );
+   * Register the device
+  p = strcpy(devname, "/dev/fb0");
+  *(--p) = '0' + minor;
+  status = rtems_io_register_name (devname, major, 0);
+  if (status != RTEMS_SUCCESSFUL) {
+    fbst->found = -1;
+    printk("Error registering /dev/fbX FBCIRRUS framebuffer device!\n");
+    rtems_fatal_error_occurred( status );
+  fbst->found = 1;
+  return RTEMS_SUCCESSFUL;
+ * fbvga device driver OPEN entry point
+rtems_device_driver frame_buffer_open(
+  void                      *arg
+  int line_bytes;
+  if (pthread_mutex_trylock(&mutex)!= 0) {
+    printk( "FBCIRRUS open cannot grab mutex.\n" );
+  printf("FBCIRRUS found %d pbus %d pdev %d pfun %d\n",
+    fbst->found, fbst->pbus, fbst->pdev, fbst->pfun);
+  fb_cirrus_read_config_dword(fbst, PCI_BASE_ADDRESS_0, &fbst->pci_bar[0]);
+  fb_cirrus_read_config_dword(fbst, PCI_BASE_ADDRESS_1, &fbst->pci_bar[1]);
+  fb_cirrus_read_config_dword(fbst, PCI_BASE_ADDRESS_2, &fbst->pci_bar[2]);
+  fb_cirrus_read_config_dword(fbst, PCI_BASE_ADDRESS_3, &fbst->pci_bar[3]);
+  fbst->pci_bar[0] &= PCI_BASE_ADDRESS_MEM_MASK;
+  fbst->pci_bar[1] &= PCI_BASE_ADDRESS_MEM_MASK;
+  printf("FBCIRRUS PCI BARs 0x%08lx 0x%08lx 0x%08lx 0x%08lx\n",
+    fbst->pci_bar[0], fbst->pci_bar[1], fbst->pci_bar[2], fbst->pci_bar[3]);
+  if (_CPU_is_paging_enabled()) {
+    _CPU_map_phys_address((void **) &(fbst->fb_fix.smem_start),
+                            (void *)(fbst->pci_bar[0]),
+                            0x1000000 ,
+                            PTE_CACHE_DISABLE | PTE_WRITABLE);
+    _CPU_map_phys_address((void **) &(fbst->mmregs),
+                            (void *)(fbst->pci_bar[1]),
+                            0x1000,
+   } else {
+      fbst->fb_fix.smem_start = (volatile char *)fbst->pci_bar[0];
+      fbst->mmregs = (void *)fbst->pci_bar[1];
+  fbst->fb_fix.smem_len = 0x1000000;
+  fbst->fb_fix.type = FB_TYPE_PACKED_PIXELS;
+  fbst->fb_fix.visual = FB_VISUAL_TRUECOLOR;
+  printf("FBCIRRUS remapped fb 0x%08lx mmregs 0x%08lx\n",
+    (unsigned long)fbst->fb_fix.smem_start, (unsigned long)fbst->mmregs);
+  fbst->active_mode = &fb_cirrus_std_modelines[FB_CIRRUS_DEFAULT_MODE];
+  fbst->fb_var.bits_per_pixel = FB_CIRRUS_DEFAULT_BPP;
+  fbst->fb_var.xres = fbst->active_mode->hdisplay;
+  fbst->fb_var.yres = fbst->active_mode->vdisplay;
+  line_bytes = fbst->fb_var.xres * fbst->fb_var.bits_per_pixel;
+  line_bytes = (line_bytes + 7) / 8;
+  fbst->fb_fix.line_length = line_bytes;
+  fb_cirrus_set_crt_mode(fbst, fbst->active_mode);
+  printk( "FBCIRRUS open called.\n" );
+ * fbvga device driver CLOSE entry point
+rtems_device_driver frame_buffer_close(
+  void                      *arg
+  if (pthread_mutex_unlock(&mutex) == 0){
+    /* restore previous state.  for VGA this means return to text mode.
+     * leave out if graphics hardware has been initialized in
+     * frame_buffer_initialize() */
+    printk( "FBCIRRUS close called.\n" );
+ * fbvga device driver READ entry point.
+rtems_device_driver frame_buffer_read(
+  void                      *arg
+  rtems_libio_rw_args_t *rw_args = (rtems_libio_rw_args_t *)arg;
+  rw_args->bytes_moved = ((rw_args->offset + rw_args->count) > fbst->fb_fix.smem_len ) ?
+    (fbst->fb_fix.smem_len - rw_args->offset) : rw_args->count;
+  memcpy(rw_args->buffer, (const void *) (fbst->fb_fix.smem_start + rw_args->offset),
+    rw_args->bytes_moved);
+ * frame_buffer device driver WRITE entry point.
+rtems_device_driver frame_buffer_write(
+  void                      *arg
+  memcpy( (void *) (fbst->fb_fix.smem_start + rw_args->offset), rw_args->buffer,
+static int get_fix_screen_info(struct fb_cirrus_state *fbst, struct fb_fix_screeninfo *info )
+  *info = fbst->fb_fix;
+  return 0;
+static int get_var_screen_info(struct fb_cirrus_state *fbst, struct fb_var_screeninfo *info )
+  *info =  fbst->fb_var;
+  return 0;
+static int get_palette(struct fb_cirrus_state *fbst, struct fb_cmap *cmap )
+  uint32_t i;
+  if ( cmap->start + cmap->len >= 16 )
+    return 1;
+  for( i = 0; i < cmap->len; i++ ) {
+    cmap->red[ cmap->start + i ]   = red16[ cmap->start + i ];
+    cmap->green[ cmap->start + i ] = green16[ cmap->start + i ];
+    cmap->blue[ cmap->start + i ]  = blue16[ cmap->start + i ];
+  return 0;
+static int set_palette(struct fb_cirrus_state *fbst, struct fb_cmap *cmap )
+  uint32_t i;
+    return 1;
+    red16[ cmap->start + i ] = cmap->red[ cmap->start + i ];
+    green16[ cmap->start + i ] = cmap->green[ cmap->start + i ];
+    blue16[ cmap->start + i ] = cmap->blue[ cmap->start + i ];
+  return 0;
+ * IOCTL entry point -- This method is called to carry
+ * all services of this interface.
+rtems_device_driver frame_buffer_control(
+  void                      *arg
+  rtems_libio_ioctl_args_t *args = arg;
+  printk( "FBCIRRUS ioctl called, cmd=%x\n", args->command  );
+  switch( args->command ) {
+    case FBIOGET_FSCREENINFO:
+      args->ioctl_return =  get_fix_screen_info( fbst, ( struct fb_fix_screeninfo * ) args->buffer );
+      break;
+    case FBIOGET_VSCREENINFO:
+      args->ioctl_return =  get_var_screen_info( fbst, ( struct fb_var_screeninfo * ) args->buffer );
+      break;
+    case FBIOPUT_VSCREENINFO:
+      /* not implemented yet*/
+      args->ioctl_return = -1;
+    case FBIOGETCMAP:
+      args->ioctl_return =  get_palette( fbst, ( struct fb_cmap * ) args->buffer );
+      break;
+    case FBIOPUTCMAP:
+      args->ioctl_return =  set_palette( fbst, ( struct fb_cmap * ) args->buffer );
+      break;
+    default:
+     args->ioctl_return = 0;
+     break;
diff --git a/c/src/lib/libbsp/i386/pc386/console/vga_registers.h b/c/src/lib/libbsp/i386/pc386/console/vga_registers.h
index 0000000..816269f
--- /dev/null
+++ b/c/src/lib/libbsp/i386/pc386/console/vga_registers.h
@@ -0,0 +1,102 @@
+ * Copyright (c) 1992, 1993, 1996
+ *	Berkeley Software Design, Inc.  All rights reserved.
+ * are met:
+ * 3. All advertising materials mentioning features or use of this software
+ *    must display the following acknowledgement:
+ *	This product includes software developed by Berkeley Software
+ *	Design, Inc.
+ * THIS SOFTWARE IS PROVIDED BY Berkeley Software Design, Inc. ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL Berkeley Software Design, Inc. BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ *	BSDI video.h,v 2.2 1996/04/08 19:33:12 bostic Exp
+ * Subset of the full header file adapted for RTEMS operating system from
+ *      FreeBSD: src/usr.bin/doscmd/video.h,v 1.2.2.1 2002/04/25 11:04:51 tg Exp $
+/* CRTC registers
+   We use the VGA register functions and don't care about the MDA. We also
+   leave out the undocumented registers at 0x22, 0x24, 0x3?. */
+#define	CRTC_HorzTotal		0x00
+#define	CRTC_HorzDispEnd	0x01
+#define CRTC_StartHorzBlank	0x02
+#define	CRTC_EndHorzBlank	0x03
+#define	CRTC_StartHorzRetrace	0x04
+#define	CRTC_EndHorzRetrace	0x05
+#define	CRTC_VertTotal		0x06
+#define	CRTC_Overflow		0x07
+#define	CRTC_ResetRowScan	0x08
+#define	CRTC_MaxScanLine	0x09
+#define	CRTC_CursStart		0x0a
+#define	CRTC_CursEnd		0x0b
+#define	CRTC_StartAddrHi	0x0c
+#define	CRTC_StartAddrLo	0x0d
+#define	CRTC_CurLocHi		0x0e
+#define	CRTC_CurLocLo		0x0f
+#define CRTC_StartVertRetrace	0x10
+#define CRTC_EndVertRetrace	0x11
+#define CRTC_VertDispEnd	0x12
+#define CRTC_Offset		0x13
+#define CRTC_UnderlineLoc	0x14
+#define CRTC_StartVertBlank	0x15
+#define CRTC_EndVertBlank	0x16
+#define CRTC_ModeCtrl		0x17
+#define CRTC_LineCompare	0x18
+#define CRTC_Size		0x19
+/* Port addresses for the CRTC
+   The registers are read by
+   	OUT index_port, reg_nr
+	IN  data_port, res
+   They are written by
+	OUT data_port, value
+#define	CRTC_IndexPortColor	0x03d4	/* CRTC Address Register (Color) */
+#define	CRTC_DataPortColor	0x03d5	/* CRTC Data Register (Color) */
+#define	CRTC_IndexPortMono	0x03b4	/* CRTC Address Register (Mono) */
+#define	CRTC_DataPortMono	0x03b5	/* CRTC Data Register (Mono) */
+/* GDC registers */
+#define GDC_SetReset		0x00
+#define GDC_EnableSetReset	0x01
+#define GDC_ColorCompare	0x02
+#define GDC_DataRotate		0x03
+#define GDC_ReadMapSelect	0x04
+#define GDC_Mode		0x05
+#define GDC_Misc		0x06
+#define GDC_ColorDontCare	0x07
+#define GDC_BitMask		0x08
+#define GDC_Size		0x09
+/* Port addresses for the GDC */
+#define GDC_IndexPort		0x03ce
+#define GDC_DataPort		0x03cf
1.7.10
