Fwd: [GSOC]Pork error: Function not implemented[deb]
Xiaochen Pan
panx at seas.upenn.edu
Sun Jun 24 13:50:25 UTC 2012
So, is it because I disabled posix when building rtems? I will try.
Begin forwarded message:
> From: panx at seas.upenn.edu
> Subject: [GSOC]Pork error: Function not implemented[deb]
> Date: June 23, 2012 6:28:18 PM EDT
> To: rtems-devel at rtems.org
> Hi,
> When I use sparc-rtems4.11-run command to run the executable file for certain tests application, it first print something in the program:
> ->T1 [IN PROGRESS]
> which should be printed out as normal.
> Then it comes out this error message:
> Fork error: Function not implemented.
> This testing framework probably depends on forking the process to do the tests stuff in order to avoid interferering with running application. Forking a process shouldn't be in the way. But I am not that familiar with RTEMS. So, I wonder are there anything special with the RTEMS in process management?
> regards,
> xiaochen
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120624/24eed478/attachment.html>
