Fwd: [GSOC]Pork error: Function not implemented[deb]
Sun Jun 24 14:07:12 UTC 2012
Rtems is single process and does not support fork(), exec(), shm*() or mmap() methods. You will have to find a way around this or the package is not meant for environments which follow POSIX profiles 51 or 52. 53 and 54 include processes
--joel
Xiaochen Pan <panx at seas.upenn.edu> wrote:
>So, is it because I disabled posix when building rtems? I will try.
>Begin forwarded message:
>From: panx at seas.upenn.edu<mailto:panx at seas.upenn.edu>
>Subject: [GSOC]Pork error: Function not implemented[deb]
>Date: June 23, 2012 6:28:18 PM EDT
>To: rtems-devel at rtems.org<mailto:rtems-devel at rtems.org>
>Hi,
>When I use sparc-rtems4.11-run command to run the executable file for certain tests application, it first print something in the program:
>->T1 [IN PROGRESS]
>which should be printed out as normal.
>Then it comes out this error message:
>Fork error: Function not implemented.
>This testing framework probably depends on forking the process to do the tests stuff in order to avoid interferering with running application. Forking a process shouldn't be in the way. But I am not that familiar with RTEMS. So, I wonder are there anything special with the RTEMS in process management?
>regards,
>xiaochen
