Discuss the replacement strategy interface in bdbuf
Tue Jun 26 08:31:48 UTC 2012
On 06/25/2012 11:08 AM, Xiang Cui wrote:
> Hi
> I want to change the replacement strategy in bdbuf. The strategy in
> bdbuf now is LRU. The detail information can be seen in Block Device
> Buffer Management[1]. The field rtems_chain_node link is used to link
> the buffer onto a number of lists.  State with CACHED and MODIFIED
> can be hit in upper layer. That means they are neither in LRU List or
> in Modified List before change state.
The list membership depends on the state and is documented in the table here:
http://www.rtems.org/onlinedocs/doxygen/cpukit/html/group__rtems__bdbuf.html#ga0169f36547d36f0723b6456172eeef0a
> Task swapout ceaselessly change the buffer state from MODIFIED to
> TRANSFER then CACHED.
> The main purpose of the replacement policy is to find the victim
> buffer to replace. This purpose is now done by maintaining the LRU
> list. When a buffer is Transfer done or Released, it will be add the
> to the tail. When the cache miss, the buffer management will look for
> the buffer from the head in LRU list to replace. If no suitable buffer
> in LRU list, it will wait.
> The design in bdbuf now works fine with LRU, but not friendly with
> other algorithm like clock which use a reference bit to indicate
> accessed. Another trouble here is when block size changed, the cached
> buffer need be reallocated.
> I want some guide about how the replacement strategy interface should
> be in bdbuf.
Which data structures do you need to implement the other algorithms?  It would
be nice if you can elaborate this a bit for the interested mailing list readers.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
