How to run and debug the rtems SMP applications and test cases
yangwei weiyang
wei.a.yang at gmail.com
Tue Jun 26 13:56:41 UTC 2012
Hi all,
How to run and debug the rtems SMP applications and test cases for
i386? I have build the rtems with the follow command:
../rtems/configure --target=i386-rtems4.11
--prefix=/sdb1/gsoc2012/github/rtems-install --enable-smp
--enable-tests=yes --enable-rtemsbsp=pcp4
After i made a boot image and run it on vmware i386 the smptest test
case are all failed. Any one can give me some advice?
Wei Yang
Best Regards
