[GSOC] How to enable floating point? (Deb)
Tue Jun 26 16:09:28 UTC 2012
On Mon, Jun 25, 2012 at 11:50 PM, Xiaochen Pan <panx at seas.upenn.edu> wrote:
> Can rtems_task_create() be used at the same time of main() function and without rtems_task_initiate()? Does it have any example written in this way?
$ cd testsuites/sptests
$ grep -r "CONFIGURE_INIT_TASK_ATTRIBUTES" *
sp19/system.h:#define CONFIGURE_INIT_TASK_ATTRIBUTES    RTEMS_FLOATING_POINT
It also looks like libtests/math (and libtests/mathl and mathf) use
both main() and floating point so those might be more helpful to you.
Check out sp19. There are also some examples in libtests (and paranoia
in samples).
> On Jun 25, 2012, at 3:18 AM, Sebastian Huber wrote:
>> You have to set the floating point attribute in rtems_task_create().  For the initialization task use CONFIGURE_INIT_TASK_ATTRIBUTES.
>> On 06/25/2012 03:03 AM, Xiaochen Pan wrote:
>>> Hi,
>>> I got this message when running some code:
>>> Unexpected trap ( 4) at address 0x020051EC
>>> fp disabled
>>> It says floating point being disabled. Can I enable floating point operation?
>>> Does this property apply to all BSPs? What I can do about it?
>>> regards,
>>> xiaochen
>>> rtems-devel mailing list
>>> rtems-devel at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-devel
>> Sebastian Huber, embedded brains GmbH
>> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
>> Phone   : +49 89 18 90 80 79-6
>> Fax     : +49 89 18 90 80 79-9
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
