[GSOC] How to fix this path problem?
Xiaochen Pan
panx at seas.upenn.edu
Wed Jun 20 02:52:42 UTC 2012
Thank you very much.
I have used the virtual machine image of centos and rebuilt and reinstalled the rtems according to the webpage.
After I have reinstalled it, I want to build the testsuites in the rtems directory from the start, aka, configure and make, even though there are ' .exe' files already produced by the installation process.
For the previous email, the error command is:
sparc-rtems4.11-gcc -specs bsp_specs -qrtems -g -O2 -mcu=cypress -o sp01.exe init.o task1.o
I have exported the environment variables as follows:
export RTEMS_MAKEFILE_PATH = /opt/rtems-4.11/sparc-rtems4.11/sis
export PATH = /opt/rtems-4.11/bin:/opt/rtems-4.11/sparc-rtems4.11/sis/lib:$PATH
export C_INCLUDE_FILE=/opt/rtems-4.11/sparc-rtems4.11/sis/lib/include
It can't locate bsp_specs and linkcmds, both of which are in the /opt/rtems-4.11/sparc-rtems4.11/sis/lib directory, which is already exported.
I am emailing to ask where I was wrong about the configuation.
In addition, where should I put the source files for new application in order to build the application? Where are the templates for autoconf and automake tools inputs files? And for the make/custom/sis.cfg, where should they be placed in order to build the application successfully?
Regards,
xiaochen
On Jun 19, 2012, at 12:33 PM, Ralf Corsepius wrote:
> On 06/19/2012 06:18 PM, Gedare Bloom wrote:
>> Please post how you configured rtems, how you made rtems, and how you
>> installed rtems.
> More important than this is sending the call which triggers this error message.
> I am pretty sure the OP is missing an argument to a compiler call.
> Ralf
