[GSOC] How to compile with sparc-rtems4.11-g++ command?
Thu Jun 21 21:48:17 UTC 2012
I suspect a bug in your makefile where $(ARCH) is not before $(OBJS).
Notice in this fragement all depends on $(ARCH) and $(PGM).
$(PGM) depends on $(OBJS). $(ARCH) will be "built" before $(PGM)'s
dependencies are addressed.
all:    ${ARCH} $(PGM)
$(PGM): $(OBJS)
         $(make-exe)
If that isn't it, send me a tarball and I will look at it.
--joel
On 06/21/2012 04:30 PM, panx at seas.upenn.edu wrote:
> Sorry, I also modified it to be
> CXXSRCS = runner.cpp
> CXXOBJS = $(CSRCS:%.cpp=${ARCH}/%.o)
> Quoting panx at seas.upenn.edu:
>> Here is another one error message:
>> sparc-rtems4.11-g++
>> -B/home/rtems/rtems-4.11-work/b-sis/sparc-rtems4.11/sis/lib/ -specs
>> bsp_specs -qrtems   -g -Wall  -g    -mcpu=cypress     -c   -o
>> o-optimize/runner.o runner.cc
>> Assembler messages:
>> Fatal error: can't create o-optimize/runner.o: No such file or directory
>> make: *** [o-optimize/runner.o] Error 1
>> In the makefile from example-v2, I modified the following part:
>> CSRCS = test.c
>> COBJS = $(CSRCS:%.c=${ARCH}/%.o)
>> to be like this:
>> CSRCS = runner.cpp
>> COBJS = $(CSRCS:%.cpp=${ARCH}/%.o)
>> Which part I was not doing correctly?
>> Regards,
>> xiaochen
>> Quoting Joel Sherrill<joel.sherrill at OARcorp.com>:
>>> On 06/21/2012 03:54 PM, Xiaochen Pan wrote:
>>>> Hello all,
>>>> Here is the command:
>>>> sparc-rtems4.11-g++ -o runner runner.cpp
>>> You are still not building with the arguments to have RTEMS and the
>>> BSP .h files available or included with your application.
>>> If you use the Makefiles from examples-v2, simply list your C++
>>> sources as CXXSRCS like this
>>> CXXSRCS = init.cc
>>>> Here are the error messages:
>>>> */opt/rtems-4.11/lib/gcc/sparc-rtems4.11/4.6.2/../../../../sparc-rtems4.11/bin/ld: warning: cannot find entry symbol _start; defaulting to
>>>> 00010074
>>>> /opt/rtems-4.11/lib/gcc/sparc-rtems4.11/4.6.2/libstdc++.a(eh_alloc.o): In
>>>> function `__gthread_mutex_destroy':
>>>> /builddir/build/BUILD/rtems-4.11-sparc-rtems4.11-gcc-4.6.2/build/sparc-rtems4.11/libstdc++-v3/include/sparc-rtems4.11/bits/gthr-default.h:114: undefined reference to
>>>> `rtems_gxx_mutex_destroy'
>>>> /opt/rtems-4.11/lib/gcc/sparc-rtems4.11/4.6.2/libstdc++.a(locale.o): In
>>>> /opt/rtems-4.11/lib/gcc/sparc-rtems4.11/4.6.2/libstdc++.a(locale_init.o):
>>>> In function `__gthread_mutex_destroy':
>>>> collect2: ld returned 1 exit status*
>>>> How to fix this problem?
>>>> regards,
>>>> xiaochen
>>> Joel Sherrill, Ph.D.             Director of Research&    Development
>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>     Support Available             (256) 722-9985
