Why there is no BSP support for Mini2440 while there is a port for Mini2440 out there?
Gedare Bloom
gedare at rtems.org
Sun Jun 24 18:46:25 UTC 2012
Hi,
You might try asking if anyone has experience with it on rtems-users
mailing list. As for the question in the subject line, RTEMS will
support a port/bsp if someone contributes it (and there is user
interest in it); someone has to be motivated enough to get this code
working and submit it. The best scenario is for the original authors
to submit the code, and perhaps you should ask Bacon Xu about
submitting the port/bsp.
-Gedare
On Sat, Jun 23, 2012 at 3:37 PM, SAeeD <salpha.2004 at gmail.com> wrote:
> Hello everyone,
> I think the subject is clear enough. While looking for a port of RTEMS to
> Mini2440, I found this Git which is owned by Bacon Xu.
> Bacon has successfully booted RTEMS on QEMU, simulating Mini2440 board. His
> Blog contains some notes about this port.
> Although I'm not sure that QEMU configuration is maximal for simulating all
> details of Mini2440 platform, I wonder has any one ever tried to use the
> ported version of Bacon's RTEMS for Mini2440? Is it working on real HW?
> Thanks in advance
> SAeeD
> rtems-devel mailing list
> rtems-devel at rtems.org
