[PATCH] score: Add _RBTree_Opposite_direction.
Gedare Bloom
gedare at rtems.org
Sun Mar 4 18:24:53 UTC 2012
Add a red-black tree helper method to ease obtaining the direction opposite
to the current direction. Useful for manipulating and traversing an rbtree.
cpukit/score/inline/rtems/score/rbtree.inl | 16 +++++++++++++---
cpukit/score/src/rbtreeextract.c | 10 +++++-----
2 files changed, 18 insertions(+), 8 deletions(-)
diff --git a/cpukit/score/inline/rtems/score/rbtree.inl b/cpukit/score/inline/rtems/score/rbtree.inl
index bbc6047..ef653e5 100644
--- a/cpukit/score/inline/rtems/score/rbtree.inl
+++ b/cpukit/score/inline/rtems/score/rbtree.inl
@@ -31,6 +31,16 @@
+ * @brief Get the direction opposite to @a the_dir
+RTEMS_INLINE_ROUTINE RBTree_Direction _RBTree_Opposite_direction(
+ RBTree_Direction the_dir
+ return (!the_dir);
/** @brief Set off rbtree
* This function sets the parent and child fields of the @a node to NULL
@@ -435,10 +445,10 @@ RTEMS_INLINE_ROUTINE void _RBTree_Rotate(
RBTree_Node *c;
if (the_node == NULL) return;
- if (the_node->child[(1-dir)] == NULL) return;
+ if (the_node->child[_RBTree_Opposite_direction(dir)] == NULL) return;
- c = the_node->child[(1-dir)];
- the_node->child[(1-dir)] = c->child[dir];
+ c = the_node->child[_RBTree_Opposite_direction(dir)];
+ the_node->child[_RBTree_Opposite_direction(dir)] = c->child[dir];
if (c->child[dir])
c->child[dir]->parent = the_node;
diff --git a/cpukit/score/src/rbtreeextract.c b/cpukit/score/src/rbtreeextract.c
index ecbda18..4071361 100644
--- a/cpukit/score/src/rbtreeextract.c
+++ b/cpukit/score/src/rbtreeextract.c
@@ -50,7 +50,7 @@ static void _RBTree_Extract_validate_unprotected(
sibling->color = RBT_BLACK;
dir = the_node != parent->child[0];
_RBTree_Rotate(parent, dir);
- sibling = parent->child[!dir];
+ sibling = parent->child[_RBTree_Opposite_direction(dir)];
/* sibling is black, see if both of its children are also black. */
@@ -72,15 +72,15 @@ static void _RBTree_Extract_validate_unprotected(
* Then switch the sibling and parent colors, and rotate through parent.
- if (!_RBTree_Is_red(sibling->child[!dir])) {
+ if (!_RBTree_Is_red(sibling->child[_RBTree_Opposite_direction(dir)])) {
sibling->color = RBT_RED;
sibling->child[dir]->color = RBT_BLACK;
- _RBTree_Rotate(sibling, !dir);
+ _RBTree_Rotate(sibling, _RBTree_Opposite_direction(dir));
sibling->color = parent->color;
parent->color = RBT_BLACK;
- sibling->child[!dir]->color = RBT_BLACK;
+ sibling->child[_RBTree_Opposite_direction(dir)]->color = RBT_BLACK;
break; /* done */
1.7.4.4
