Fwd: GCC 4.7.0 Release Candidate available from gcc.gnu.org
Ralf Corsepius ralf.corsepius at rtems.org
Mon Mar 5 15:39:52 UTC 2012
On 03/05/2012 12:14 PM, Sebastian Huber wrote:
> On 03/05/2012 12:03 PM, Ralf Corsepius wrote:
>> arm-rtems* fails with this:
>> *** Configuration arm-unknown-rtems4.11 is obsolete.
>> *** Specify --enable-obsolete to build it anyway.
>> *** Support will be REMOVED in the next major release of GCC,
>> *** unless a maintainer comes forward.
>> ... I am speechless about this jerkery :(
> This configuration is in fact obsolete. Anyone using it should switch to
> the EABI configuration as soon as possible.
Keyword: _should_ ... compare this to your "short enums" issues.
I read this as "wishful thinking outrules reason and practice".
Ralf
