git send-bugzilla
Mon Mar 5 19:23:49 UTC 2012
On 03/04/2012 09:14 PM, Gedare Bloom wrote:
> Hi,
> I installed git-send-bugzilla on my desktop and have properly
> configured it. I would like to use it to send patches directly to PRs.
> Is there something that should be done on the server side to support
> such capability?
> When I try, I get:
> Logging in as gedare at rtems.org...
> Error GETing https://www.rtems.org/bugzilla/?GoAheadAndLogIn=1: Can't
> connect to www.rtems.org:443 (SSL connect attempt failed with unknown
> errorerror:14090086:SSL
> routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed) at
> /usr/bin/git-send-bugzilla line 40
> By the way I have disabled sslVerify in my git config for now.
rtems.org hosts a number of virtual hosts by name rather
than by IP address. The SSL certificate can only be associated
with 1 name. In this case, it is rtems.org.
I don't know where the script is but changing the
www.rtems.org to just rtems.org should fix it.
> -Gedare
> rtems-devel mailing list
> rtems-devel at rtems.org
Joel Sherrill, Ph.D.             Director of Research&   Development
