[PATCH] confdefs: Add declaration for unlimited objects.
Mon Mar 26 21:52:21 UTC 2012
If any intrepid potential GSOC students want to take a crack at
writing a patch this could be a good opportunity! :)
/me doesn't want to write doc right now ;)
-Gedare
On Mon, Mar 26, 2012 at 5:38 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On 03/26/2012 04:31 PM, Gedare Bloom wrote:
>> Messed up :) This description should have preceded the patch. Oh well.
>> I wrote this because of a request in IRC (By Peer) asking whether a
>> similar mechanism existed.
> I think this is a handy option. If you will add some documentation
> to doc/user/conf.t, then it is OK to apply.
>> -Gedare
>> On Mon, Mar 26, 2012 at 5:28 PM, Gedare Bloom<gedare at rtems.org>  wrote:
>>> This patch adds a macro to ease writing a configuration when the user
>>> does not care about resource limits / determinism. Such a case arises
>>> frequently when porting software to RTEMS when the precise resource
>>> requirements of the software is unknown. By allowing users to declare
>>> all resources as being unlimited the user will be able to easily avoid
>>> having to identify which resources are included and define the resource
>>> limits.
>>> I tested this patch only with the unlimited sample, which uses unlimited
>>> tasks. The other classic resources and posix resources have not been
>>> tested
>>> to verify that they will work properly when using unlimited objects. Due
>>> to how the posix objects' memory requirements are configured in confdefs
>>> this patch does not provide unlimited declarations for posix keys or
>>> queued signals.
>>> If a user provides a value for a configured number of resources that
>>> value will be used instead of the unlimited. If a user does not specify
>>> an allocation size the default size of 8 objects is used. This macro does
>>> not
>>> support varying the allocation sizes for different objects; users who
>>> want that
>>> much control can define the unlimited macros themselves.
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
> Joel Sherrill, Ph.D.             Director of Research&   Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>    Support Available             (256) 722-9985
