[PATCH] confdefs: Add declaration for unlimited objects.
    Joel Sherrill
    joel.sherrill at OARcorp.com
    Mon Mar 26 22:51:25 UTC 2012
On 03/26/2012 05:47 PM, Peer Stritzinger wrote:
>> Adds to confdefs a way to specify rtems_resource_unlimited for classic and
>> posix objects using a new macro CONFIGURE_OBJECTS_UNLIMITED.
>> Use CONFIGURE_OBJECTS_ALLOCATION_SIZE to declare the allocation size for
>> extending the set of objects at runtime. Updates the unlimited sample
>> to demonstrate how to use the new macros.
> Tried this out and it helped already!
> I'm in the process of porting the Erlang to RTEMS and instead of
> hitting one resource limit after another I just set
> CONFIGURE_OBJECTS_UNLIMITED and get over all resource problems at
> once.  Great when porting stuff where the resource usage is completely
> unknown.
I do something similar when porting packages to RTEMS but
add in modifying the path in the Score Objects Handler when
it tells you that it has no more objects. I add a printk.  That
way I know which objects need to be unlimited.
I think most of the gcc test suite configurations are unlimited
for the objects those language run-times are known to use.
But it is certainly easier to throw a single big switch.
> Cheers
> -- Peer
> rtems-devel mailing list
> rtems-devel at rtems.org
Joel Sherrill, Ph.D.             Director of Research&   Development
