[PR 20] LEON3: fix GRETH interrupt initialization bug
Daniel Hellstrom daniel at gaisler.com
Thu Mar 29 11:52:11 UTC 2012
Fixed a bug where the vector number is used to clean and unmask
the IRQ at the IRQ controller, the irq number must be used.
Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
 .../lib/libbsp/sparc/leon3/leon_greth/leon_greth.c |    8 ++++----
 1 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/leon3/leon_greth/leon_greth.c b/c/src/lib/libbsp/sparc/leon3/leon_greth/leon_greth.c
index 341bd27..dd301d7 100644
--- a/c/src/lib/libbsp/sparc/leon3/leon_greth/leon_greth.c
+++ b/c/src/lib/libbsp/sparc/leon3/leon_greth/leon_greth.c
@@ -41,19 +41,19 @@ int rtems_leon_greth_driver_attach(
   if (device_found == 1)
 		base_addr = apbgreth.start;
-		eth_irq = apbgreth.irq + 0x10;
+		eth_irq = apbgreth.irq;
     /* clear control register and reset NIC */
     *(volatile int *) base_addr = 0;
     *(volatile int *) base_addr = GRETH_CTRL_RST;
     leon_greth_configuration.base_address = base_addr;
-    leon_greth_configuration.vector = eth_irq;
+    leon_greth_configuration.vector = eth_irq + 0x10;
     leon_greth_configuration.txd_count = TDA_COUNT;
     leon_greth_configuration.rxd_count = RDA_COUNT;
     if (rtems_greth_driver_attach( config, &leon_greth_configuration )) {
-      LEON_Clear_interrupt(leon_greth_configuration.vector);
-      LEON_Unmask_interrupt(leon_greth_configuration.vector);
+      LEON_Clear_interrupt(eth_irq);
+      LEON_Unmask_interrupt(eth_irq);
   return 0;
1.7.0.4
