[PATCH 21] SMC91111: remove old unused LEON2/LEON3 intialization code
Thu Mar 29 12:43:48 UTC 2012
I assume this code now is in the BSPs?
Ok to apply
Daniel Hellstrom <daniel at gaisler.com> wrote:
>Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
> c/src/libchip/network/smc91111.c |   36 ------------------------------------
> 1 files changed, 0 insertions(+), 36 deletions(-)
>diff --git a/c/src/libchip/network/smc91111.c b/c/src/libchip/network/smc91111.c
>index 41961ae..7070108 100644
>--- a/c/src/libchip/network/smc91111.c
>+++ b/c/src/libchip/network/smc91111.c
>@@ -895,42 +895,6 @@ int _rtems_smc91111_driver_attach (struct rtems_bsdnet_ifconfig *config,
> 	int mtu;
> 	DEBUG_FUNCTION();
>-#if 0
>- 	/* activate io area */
>- 	switch (sparc_leon23_get_psr_version()) {
>- 	case 0:
>- 	case 2:
>- 		db_printf("Activating Leon2 io port\n");
>- 		/*configure pio */
>- 		*((volatile unsigned int *)0x80000000) |= 0x10f80000;
>- 		*((volatile unsigned int *)0x800000A8) |=
>- 		    (0xe0 | chip->vector) << (8 * (chip->pio - 4));
>- 		break;
>- 	default:
>- 			unsigned long irq_pio, irq_mctrl, addr_pio, addr_mctrl;
>- 			if ((addr_pio = amba_find_apbslv_addr(VENDOR_GAISLER,
>- 						   GAISLER_PIOPORT, &irq_pio))
>- 			    && (addr_mctrl =
>- 				amba_find_apbslv_addr(VENDOR_ESA, ESA_MCTRL, &irq_mctrl))) {
>- 				LEON3_IOPORT_Regs_Map *io =
>- 				    (LEON3_IOPORT_Regs_Map *) addr_pio;
>- 				db_printf
>- 				    ("Activating Leon3 io port for smsc_lan91cxx (pio:%x mctrl:%x)\n",
>- 				     (unsigned int)addr_pio,
>- 				     (unsigned int)addr_mctrl);
>- 				*((volatile unsigned int *)addr_mctrl) |= 0x10f80000;	/*mctrl ctrl 1 */
>- 				io->irqmask |= (1 << chip->pio);
>- 				io->irqpol |= (1 << chip->pio);
>- 				io->irqedge |= (1 << chip->pio);
>- 				io->iodir &= ~(1 << chip->pio);
>- 			} else {
>- 				return 0;
>-#endif
> 	/* parse driver name */
> 	if ((unitNumber = rtems_bsdnet_parse_driver_name(config, &unitName)) < 0) {
> 		db_printf("Unitnumber < 0: %d\n", unitNumber);
>1.7.0.4
>_______________________________________________
>rtems-devel mailing list
>rtems-devel at rtems.org
>http://www.rtems.org/mailman/listinfo/rtems-devel
