[PATCH 21] SMC91111: remove old unused LEON2/LEON3 intialization code
Thu Mar 29 14:34:47 UTC 2012
In spite of whatever I am doing in git, this appears to be committed.
On 03/29/2012 06:52 AM, Daniel Hellstrom wrote:
> Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
>   c/src/libchip/network/smc91111.c |   36 ------------------------------------
>   1 files changed, 0 insertions(+), 36 deletions(-)
> diff --git a/c/src/libchip/network/smc91111.c b/c/src/libchip/network/smc91111.c
> index 41961ae..7070108 100644
> --- a/c/src/libchip/network/smc91111.c
> +++ b/c/src/libchip/network/smc91111.c
> @@ -895,42 +895,6 @@ int _rtems_smc91111_driver_attach (struct rtems_bsdnet_ifconfig *config,
>   	int mtu;
>   	DEBUG_FUNCTION();
> -#if 0
> - 	/* activate io area */
> - 	switch (sparc_leon23_get_psr_version()) {
> - 	case 0:
> - 	case 2:
> - 		db_printf("Activating Leon2 io port\n");
> - 		/*configure pio */
> - 		*((volatile unsigned int *)0x80000000) |= 0x10f80000;
> - 		*((volatile unsigned int *)0x800000A8) |=
> - 		    (0xe0 | chip->vector)<<  (8 * (chip->pio - 4));
> - 		break;
> - 	default:
> - 			unsigned long irq_pio, irq_mctrl, addr_pio, addr_mctrl;
> - 			if ((addr_pio = amba_find_apbslv_addr(VENDOR_GAISLER,
> - 						   GAISLER_PIOPORT,&irq_pio))
> - 			&&  (addr_mctrl =
> - 				amba_find_apbslv_addr(VENDOR_ESA, ESA_MCTRL,&irq_mctrl))) {
> - 				LEON3_IOPORT_Regs_Map *io =
> - 				    (LEON3_IOPORT_Regs_Map *) addr_pio;
> - 				db_printf
> - 				    ("Activating Leon3 io port for smsc_lan91cxx (pio:%x mctrl:%x)\n",
> - 				     (unsigned int)addr_pio,
> - 				     (unsigned int)addr_mctrl);
> - 				*((volatile unsigned int *)addr_mctrl) |= 0x10f80000;	/*mctrl ctrl 1 */
> - 				io->irqmask |= (1<<  chip->pio);
> - 				io->irqpol |= (1<<  chip->pio);
> - 				io->irqedge |= (1<<  chip->pio);
> - 				io->iodir&= ~(1<<  chip->pio);
> - 			} else {
> - 				return 0;
> -#endif
>   	/* parse driver name */
>   	if ((unitNumber = rtems_bsdnet_parse_driver_name(config,&unitName))<  0) {
>   		db_printf("Unitnumber<  0: %d\n", unitNumber);
Joel Sherrill, Ph.D.             Director of Research&   Development
