[PATCH 22] LEON3: clock timer indexing should be consequent
Thu Mar 29 19:09:12 UTC 2012
Applied.
On Thu, Mar 29, 2012 at 8:44 AM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> Ok to apply
> Daniel Hellstrom <daniel at gaisler.com> wrote:
>>Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
>> c/src/lib/libbsp/sparc/leon3/clock/ckinit.c |    6 +++---
>> 1 files changed, 3 insertions(+), 3 deletions(-)
>>diff --git a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
>>index 86a968f..932b8fd 100644
>>--- a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
>>+++ b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
>>@@ -54,7 +54,7 @@ static int clkirq;
>>     } while(0)
>> #else
>>-  #define Adjust_clkirq_for_node()
>>+  #define Adjust_clkirq_for_node() do { clkirq += LEON3_CLOCK_INDEX; } while(0)
>> #endif
>> #define Clock_driver_support_find_timer() \
>>@@ -102,10 +102,10 @@ uint32_t bsp_clock_nanoseconds_since_last_tick(void)
>>   if ( !LEON3_Timer_Regs )
>>     return 0;
>>-  clicks = LEON3_Timer_Regs->timer[0].value;
>>+  clicks = LEON3_Timer_Regs->timer[LEON3_CLOCK_INDEX].value;
>>   if ( LEON_Is_interrupt_pending( clkirq ) ) {
>>     usecs = (2*rtems_configuration_get_microseconds_per_tick() - clicks);
>>   } else {
>>     usecs = (rtems_configuration_get_microseconds_per_tick() - clicks);
>>1.7.0.4
>>_______________________________________________
>>rtems-devel mailing list
>>rtems-devel at rtems.org
>>http://www.rtems.org/mailman/listinfo/rtems-devel
