[PATCH 24] SPARC BSPS: added defines for set_vec type argument to bsp.h
Thu Mar 29 19:45:11 UTC 2012
looks good
On Thu, Mar 29, 2012 at 7:52 AM, Daniel Hellstrom <daniel at gaisler.com> wrote:
> Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
>  c/src/lib/libbsp/sparc/erc32/include/bsp.h    |    4 ++++
>  c/src/lib/libbsp/sparc/erc32/startup/setvec.c |    2 +-
>  c/src/lib/libbsp/sparc/leon2/include/bsp.h    |    4 ++++
>  c/src/lib/libbsp/sparc/leon2/startup/setvec.c |    2 +-
>  c/src/lib/libbsp/sparc/leon3/include/bsp.h    |    4 ++++
>  c/src/lib/libbsp/sparc/leon3/startup/setvec.c |    2 +-
>  6 files changed, 15 insertions(+), 3 deletions(-)
> diff --git a/c/src/lib/libbsp/sparc/erc32/include/bsp.h b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
> index a88673e..70f1ce3 100644
> --- a/c/src/lib/libbsp/sparc/erc32/include/bsp.h
> +++ b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
> @@ -69,6 +69,10 @@ extern int   end;        /* last address in the program */
>  /* functions */
> +/* set_vec type */
> +#define SET_VECTOR_RAW  0  /* Raw trap handler */
> +#define SET_VECTOR_INT  1  /* Trap handler with _ISR_Handler interrupt handler */
>  rtems_isr_entry set_vector(                     /* returns old vector */
>     rtems_isr_entry     handler,                /* isr routine        */
>     rtems_vector_number vector,                 /* vector number      */
> diff --git a/c/src/lib/libbsp/sparc/erc32/startup/setvec.c b/c/src/lib/libbsp/sparc/erc32/startup/setvec.c
> index 3a7601d..7e697a0 100644
> --- a/c/src/lib/libbsp/sparc/erc32/startup/setvec.c
> +++ b/c/src/lib/libbsp/sparc/erc32/startup/setvec.c
> @@ -42,7 +42,7 @@ rtems_isr_entry set_vector(                   /* returns old vector */
>   uint32_t        real_trap;
>   uint32_t        source;
> -  if ( type )
> +  if ( type == SET_VECTOR_INT )
>     rtems_interrupt_catch( handler, vector, &previous_isr );
>   else
>     _CPU_ISR_install_raw_handler( vector, handler, (void *)&previous_isr );
> diff --git a/c/src/lib/libbsp/sparc/leon2/include/bsp.h b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
> index 796290e..a2f3360 100644
> --- a/c/src/lib/libbsp/sparc/leon2/include/bsp.h
> +++ b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
> @@ -88,6 +88,10 @@ extern int   end;        /* last address in the program */
>  /* miscellaneous stuff assumed to exist */
> +/* set_vec type */
> diff --git a/c/src/lib/libbsp/sparc/leon2/startup/setvec.c b/c/src/lib/libbsp/sparc/leon2/startup/setvec.c
> index c7b8af6..028b17a 100644
> --- a/c/src/lib/libbsp/sparc/leon2/startup/setvec.c
> +++ b/c/src/lib/libbsp/sparc/leon2/startup/setvec.c
>   uint32_t      real_trap;
>   uint32_t      source;
> -  if ( type )
>   else
> diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp.h b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
> index 07a7412..04279d9 100644
> --- a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
> +++ b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
> @@ -98,6 +98,10 @@ extern int   end;        /* last address in the program */
> +/* set_vec type */
> diff --git a/c/src/lib/libbsp/sparc/leon3/startup/setvec.c b/c/src/lib/libbsp/sparc/leon3/startup/setvec.c
> --- a/c/src/lib/libbsp/sparc/leon3/startup/setvec.c
> +++ b/c/src/lib/libbsp/sparc/leon3/startup/setvec.c
>   uint32_t      real_trap;
>   uint32_t      source;
> -  if ( type )
>   else
> 1.7.0.4
> rtems-devel mailing list
> rtems-devel at rtems.org
