[PATCH 24] SPARC BSPS: added defines for set_vec type argument to bsp.h
Thu Mar 29 19:48:58 UTC 2012
On 03/29/2012 02:45 PM, Gedare Bloom wrote:
> looks good
I am OK with it also but it seems like set_vector() is a
required part of BSPs for the Simple Vectored Architectures.
Shouldn't the prototype and any constants associated
with it be in a common header file?
And maybe (I hate to suggest this), it be renamed
to bsp_set_vector() per current naming guidelines.
> On Thu, Mar 29, 2012 at 7:52 AM, Daniel Hellstrom<daniel at gaisler.com>  wrote:
>> Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
>>   c/src/lib/libbsp/sparc/erc32/include/bsp.h    |    4 ++++
>>   c/src/lib/libbsp/sparc/erc32/startup/setvec.c |    2 +-
>>   c/src/lib/libbsp/sparc/leon2/include/bsp.h    |    4 ++++
>>   c/src/lib/libbsp/sparc/leon2/startup/setvec.c |    2 +-
>>   c/src/lib/libbsp/sparc/leon3/include/bsp.h    |    4 ++++
>>   c/src/lib/libbsp/sparc/leon3/startup/setvec.c |    2 +-
>>   6 files changed, 15 insertions(+), 3 deletions(-)
>> diff --git a/c/src/lib/libbsp/sparc/erc32/include/bsp.h b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
>> index a88673e..70f1ce3 100644
>> --- a/c/src/lib/libbsp/sparc/erc32/include/bsp.h
>> +++ b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
>> @@ -69,6 +69,10 @@ extern int   end;        /* last address in the program */
>>   /* functions */
>> +/* set_vec type */
>> +#define SET_VECTOR_RAW  0  /* Raw trap handler */
>> +#define SET_VECTOR_INT  1  /* Trap handler with _ISR_Handler interrupt handler */
>>   rtems_isr_entry set_vector(                     /* returns old vector */
>>      rtems_isr_entry     handler,                /* isr routine        */
>>      rtems_vector_number vector,                 /* vector number      */
>> diff --git a/c/src/lib/libbsp/sparc/erc32/startup/setvec.c b/c/src/lib/libbsp/sparc/erc32/startup/setvec.c
>> index 3a7601d..7e697a0 100644
>> --- a/c/src/lib/libbsp/sparc/erc32/startup/setvec.c
>> +++ b/c/src/lib/libbsp/sparc/erc32/startup/setvec.c
>> @@ -42,7 +42,7 @@ rtems_isr_entry set_vector(                   /* returns old vector */
>>    uint32_t        real_trap;
>>    uint32_t        source;
>> -  if ( type )
>> +  if ( type == SET_VECTOR_INT )
>>      rtems_interrupt_catch( handler, vector,&previous_isr );
>>    else
>>      _CPU_ISR_install_raw_handler( vector, handler, (void *)&previous_isr );
>> diff --git a/c/src/lib/libbsp/sparc/leon2/include/bsp.h b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
>> index 796290e..a2f3360 100644
>> --- a/c/src/lib/libbsp/sparc/leon2/include/bsp.h
>> +++ b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
>> @@ -88,6 +88,10 @@ extern int   end;        /* last address in the program */
>>   /* miscellaneous stuff assumed to exist */
>> +/* set_vec type */
>> diff --git a/c/src/lib/libbsp/sparc/leon2/startup/setvec.c b/c/src/lib/libbsp/sparc/leon2/startup/setvec.c
>> index c7b8af6..028b17a 100644
>> --- a/c/src/lib/libbsp/sparc/leon2/startup/setvec.c
>> +++ b/c/src/lib/libbsp/sparc/leon2/startup/setvec.c
>>    uint32_t      real_trap;
>>    uint32_t      source;
>> -  if ( type )
>>    else
>> diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp.h b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>> index 07a7412..04279d9 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>> +++ b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>> @@ -98,6 +98,10 @@ extern int   end;        /* last address in the program */
>> +/* set_vec type */
>> diff --git a/c/src/lib/libbsp/sparc/leon3/startup/setvec.c b/c/src/lib/libbsp/sparc/leon3/startup/setvec.c
>> --- a/c/src/lib/libbsp/sparc/leon3/startup/setvec.c
>> +++ b/c/src/lib/libbsp/sparc/leon3/startup/setvec.c
>>    uint32_t      real_trap;
>>    uint32_t      source;
>> -  if ( type )
>>    else
>> 1.7.0.4
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
Joel Sherrill, Ph.D.             Director of Research&   Development
