[PATCH 24] SPARC BSPS: added defines for set_vec type argument to bsp.h
Thu Mar 29 20:09:27 UTC 2012
On 03/29/2012 02:54 PM, Gedare Bloom wrote:
> I do like the idea of pushing the macro up so that other architectures
> will implement it, but I'm not sure where the macro should live in
> that case.
If bootcard.h were "bsp_framework.h", it would be perfect. :)
For now, we are stuff with something like bsp/setvec.h.
> Renaming it is a good idea but clearly requires more consideration.
Yep. Likely to break stuff but not more than a search and replace.
> On Thu, Mar 29, 2012 at 3:48 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com>  wrote:
>> On 03/29/2012 02:45 PM, Gedare Bloom wrote:
>>> looks good
>> I am OK with it also but it seems like set_vector() is a
>> required part of BSPs for the Simple Vectored Architectures.
>> Shouldn't the prototype and any constants associated
>> with it be in a common header file?
>> And maybe (I hate to suggest this), it be renamed
>> to bsp_set_vector() per current naming guidelines.
>>> On Thu, Mar 29, 2012 at 7:52 AM, Daniel Hellstrom<daniel at gaisler.com>
>>>   wrote:
>>>> Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
>>>>   c/src/lib/libbsp/sparc/erc32/include/bsp.h    |    4 ++++
>>>>   c/src/lib/libbsp/sparc/erc32/startup/setvec.c |    2 +-
>>>>   c/src/lib/libbsp/sparc/leon2/include/bsp.h    |    4 ++++
>>>>   c/src/lib/libbsp/sparc/leon2/startup/setvec.c |    2 +-
>>>>   c/src/lib/libbsp/sparc/leon3/include/bsp.h    |    4 ++++
>>>>   c/src/lib/libbsp/sparc/leon3/startup/setvec.c |    2 +-
>>>>   6 files changed, 15 insertions(+), 3 deletions(-)
>>>> diff --git a/c/src/lib/libbsp/sparc/erc32/include/bsp.h
>>>> b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
>>>> index a88673e..70f1ce3 100644
>>>> --- a/c/src/lib/libbsp/sparc/erc32/include/bsp.h
>>>> +++ b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
>>>> @@ -69,6 +69,10 @@ extern int   end;        /* last address in the
>>>> program */
>>>>   /* functions */
>>>> +/* set_vec type */
>>>> +#define SET_VECTOR_RAW  0  /* Raw trap handler */
>>>> +#define SET_VECTOR_INT  1  /* Trap handler with _ISR_Handler interrupt
>>>> handler */
>>>>   rtems_isr_entry set_vector(                     /* returns old vector */
>>>>      rtems_isr_entry     handler,                /* isr routine        */
>>>>      rtems_vector_number vector,                 /* vector number      */
>>>> diff --git a/c/src/lib/libbsp/sparc/erc32/startup/setvec.c
>>>> b/c/src/lib/libbsp/sparc/erc32/startup/setvec.c
>>>> index 3a7601d..7e697a0 100644
>>>> --- a/c/src/lib/libbsp/sparc/erc32/startup/setvec.c
>>>> +++ b/c/src/lib/libbsp/sparc/erc32/startup/setvec.c
>>>> @@ -42,7 +42,7 @@ rtems_isr_entry set_vector(                   /*
>>>>    uint32_t        real_trap;
>>>>    uint32_t        source;
>>>> -  if ( type )
>>>> +  if ( type == SET_VECTOR_INT )
>>>>      rtems_interrupt_catch( handler, vector,&previous_isr );
>>>>    else
>>>>      _CPU_ISR_install_raw_handler( vector, handler, (void *)&previous_isr
>>>> diff --git a/c/src/lib/libbsp/sparc/leon2/include/bsp.h
>>>> b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
>>>> index 796290e..a2f3360 100644
>>>> --- a/c/src/lib/libbsp/sparc/leon2/include/bsp.h
>>>> +++ b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
>>>> @@ -88,6 +88,10 @@ extern int   end;        /* last address in the
>>>> program */
>>>>   /* miscellaneous stuff assumed to exist */
>>>> +/* set_vec type */
>>>> handler */
>>>> diff --git a/c/src/lib/libbsp/sparc/leon2/startup/setvec.c
>>>> b/c/src/lib/libbsp/sparc/leon2/startup/setvec.c
>>>> index c7b8af6..028b17a 100644
>>>> --- a/c/src/lib/libbsp/sparc/leon2/startup/setvec.c
>>>> +++ b/c/src/lib/libbsp/sparc/leon2/startup/setvec.c
>>>>    uint32_t      real_trap;
>>>>    uint32_t      source;
>>>> -  if ( type )
>>>>    else
>>>> diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>>>> b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>>>> index 07a7412..04279d9 100644
>>>> --- a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>>>> +++ b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>>>> @@ -98,6 +98,10 @@ extern int   end;        /* last address in the
>>>> program */
>>>> +/* set_vec type */
>>>> handler */
>>>> diff --git a/c/src/lib/libbsp/sparc/leon3/startup/setvec.c
>>>> b/c/src/lib/libbsp/sparc/leon3/startup/setvec.c
>>>> --- a/c/src/lib/libbsp/sparc/leon3/startup/setvec.c
>>>> +++ b/c/src/lib/libbsp/sparc/leon3/startup/setvec.c
>>>>    uint32_t      real_trap;
>>>>    uint32_t      source;
>>>> -  if ( type )
>>>>    else
>>>> 1.7.0.4
>>>> _______________________________________________
>>>> rtems-devel mailing list
>>>> rtems-devel at rtems.org
>>>> http://www.rtems.org/mailman/listinfo/rtems-devel
>> Joel Sherrill, Ph.D.             Director of Research&     Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>     Support Available             (256) 722-9985
