[PATCH 24] SPARC BSPS: added defines for set_vec type argument to bsp.h
Thu Mar 29 20:38:46 UTC 2012
On Thu, Mar 29, 2012 at 4:26 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On 03/29/2012 03:15 PM, Gedare Bloom wrote:
>> How do you want to proceed?
> I am a bit concerned about adding the constants since
> this method is supposed to be the same on all targets.
> Is this one critical Daniel? I would really like to consider
> adding a shared .h file and moving the prototype for
> all BSPs to there.
That would also allow us to eliminate the declarations of set_vector
from a bunch of bsp.h files.
>> On Thu, Mar 29, 2012 at 4:09 PM, Joel Sherrill
>>> On 03/29/2012 02:54 PM, Gedare Bloom wrote:
>>>> I do like the idea of pushing the macro up so that other architectures
>>>> will implement it, but I'm not sure where the macro should live in
>>>> that case.
>>> If bootcard.h were "bsp_framework.h", it would be perfect. :)
>>> For now, we are stuff with something like bsp/setvec.h.
>>>> Renaming it is a good idea but clearly requires more consideration.
>>> Yep. Likely to break stuff but not more than a search and replace.
>>>> On Thu, Mar 29, 2012 at 3:48 PM, Joel Sherrill
>>>>> On 03/29/2012 02:45 PM, Gedare Bloom wrote:
>>>>>> looks good
>>>>> I am OK with it also but it seems like set_vector() is a
>>>>> required part of BSPs for the Simple Vectored Architectures.
>>>>> Shouldn't the prototype and any constants associated
>>>>> with it be in a common header file?
>>>>> And maybe (I hate to suggest this), it be renamed
>>>>> to bsp_set_vector() per current naming guidelines.
>>>>>> On Thu, Mar 29, 2012 at 7:52 AM, Daniel Hellstrom<daniel at gaisler.com>
>>>>>>  wrote:
>>>>>>> Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
>>>>>>>  c/src/lib/libbsp/sparc/erc32/include/bsp.h    |    4 ++++
>>>>>>>  c/src/lib/libbsp/sparc/erc32/startup/setvec.c |    2 +-
>>>>>>>  c/src/lib/libbsp/sparc/leon2/include/bsp.h    |    4 ++++
>>>>>>>  c/src/lib/libbsp/sparc/leon2/startup/setvec.c |    2 +-
>>>>>>>  c/src/lib/libbsp/sparc/leon3/include/bsp.h    |    4 ++++
>>>>>>>  c/src/lib/libbsp/sparc/leon3/startup/setvec.c |    2 +-
>>>>>>>  6 files changed, 15 insertions(+), 3 deletions(-)
>>>>>>> diff --git a/c/src/lib/libbsp/sparc/erc32/include/bsp.h
>>>>>>> b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
>>>>>>> index a88673e..70f1ce3 100644
>>>>>>> --- a/c/src/lib/libbsp/sparc/erc32/include/bsp.h
>>>>>>> +++ b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
>>>>>>> @@ -69,6 +69,10 @@ extern int   end;        /* last address in the
>>>>>>> program */
>>>>>>>  /* functions */
>>>>>>> +/* set_vec type */
>>>>>>> +#define SET_VECTOR_RAW  0  /* Raw trap handler */
>>>>>>> +#define SET_VECTOR_INT  1  /* Trap handler with _ISR_Handler
>>>>>>> interrupt
>>>>>>> handler */
>>>>>>>  rtems_isr_entry set_vector(                     /* returns old
>>>>>>> vector
>>>>>>>     rtems_isr_entry     handler,                /* isr routine
>>>>>>>     rtems_vector_number vector,                 /* vector number
>>>>>>> diff --git a/c/src/lib/libbsp/sparc/erc32/startup/setvec.c
>>>>>>> b/c/src/lib/libbsp/sparc/erc32/startup/setvec.c
>>>>>>> index 3a7601d..7e697a0 100644
>>>>>>> --- a/c/src/lib/libbsp/sparc/erc32/startup/setvec.c
>>>>>>> +++ b/c/src/lib/libbsp/sparc/erc32/startup/setvec.c
>>>>>>> @@ -42,7 +42,7 @@ rtems_isr_entry set_vector(                   /*
>>>>>>> returns old vector */
>>>>>>>   uint32_t        real_trap;
>>>>>>>   uint32_t        source;
>>>>>>> -  if ( type )
>>>>>>> +  if ( type == SET_VECTOR_INT )
>>>>>>>     rtems_interrupt_catch( handler, vector,&previous_isr );
>>>>>>>   else
>>>>>>>     _CPU_ISR_install_raw_handler( vector, handler, (void
>>>>>>> *)&previous_isr
>>>>>>> diff --git a/c/src/lib/libbsp/sparc/leon2/include/bsp.h
>>>>>>> b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
>>>>>>> index 796290e..a2f3360 100644
>>>>>>> --- a/c/src/lib/libbsp/sparc/leon2/include/bsp.h
>>>>>>> +++ b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
>>>>>>> @@ -88,6 +88,10 @@ extern int   end;        /* last address in the
>>>>>>> program */
>>>>>>>  /* miscellaneous stuff assumed to exist */
>>>>>>> +/* set_vec type */
>>>>>>> interrupt
>>>>>>> handler */
>>>>>>> vector
>>>>>>> diff --git a/c/src/lib/libbsp/sparc/leon2/startup/setvec.c
>>>>>>> b/c/src/lib/libbsp/sparc/leon2/startup/setvec.c
>>>>>>> index c7b8af6..028b17a 100644
>>>>>>> --- a/c/src/lib/libbsp/sparc/leon2/startup/setvec.c
>>>>>>> +++ b/c/src/lib/libbsp/sparc/leon2/startup/setvec.c
>>>>>>>   uint32_t      real_trap;
>>>>>>>   uint32_t      source;
>>>>>>> -  if ( type )
>>>>>>>   else
>>>>>>> *)&previous_isr
>>>>>>> diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>>>>>>> b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>>>>>>> index 07a7412..04279d9 100644
>>>>>>> --- a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>>>>>>> +++ b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>>>>>>> @@ -98,6 +98,10 @@ extern int   end;        /* last address in the
>>>>>>> program */
>>>>>>> +/* set_vec type */
>>>>>>> interrupt
>>>>>>> handler */
>>>>>>> vector
>>>>>>> diff --git a/c/src/lib/libbsp/sparc/leon3/startup/setvec.c
>>>>>>> b/c/src/lib/libbsp/sparc/leon3/startup/setvec.c
>>>>>>> --- a/c/src/lib/libbsp/sparc/leon3/startup/setvec.c
>>>>>>> +++ b/c/src/lib/libbsp/sparc/leon3/startup/setvec.c
>>>>>>>   uint32_t      real_trap;
>>>>>>>   uint32_t      source;
>>>>>>> -  if ( type )
>>>>>>>   else
>>>>>>> *)&previous_isr
>>>>>>> 1.7.0.4
>>>>>>> _______________________________________________
>>>>>>> rtems-devel mailing list
>>>>>>> rtems-devel at rtems.org
>>>>>>> http://www.rtems.org/mailman/listinfo/rtems-devel
>>>>> Joel Sherrill, Ph.D.             Director of Research&
>>>>> Development
>>>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>>>    Support Available             (256) 722-9985
>>> Joel Sherrill, Ph.D.             Director of Research&     Development
