[GSoC]use hash/map in POSIX key and Classic notepad
阿四
ashi08104 at gmail.com
Fri Mar 30 14:50:27 UTC 2012
Hi, all. I'm interesing in the hash/map in POSIX key and Classic notepad
project[1] and want to apply it as my GSoC this year. I've submitted my
proposal at GSoC. Here are some problems I want to figure out, thanks for
reply to any of them:
1. First, I want to be sure where the entry point of this project exactly
is in the RTEMS. For the notepad, I think RTEMS_API_Control structure,
which includes the Notepads array member, is the entry of the Notepad part
of this project. And to the POSIX key, the corresponding structure is
POSIX_Keys_Control structure, and the key area mentioned in [1] is the
Values array member of POSIX_Keys_Control. Am I missing something?
typedef struct {
rtems_event_set pending_events;
rtems_event_set event_condition;
ASR_Information Signal;
uint32_t Notepads[ RTEMS_NUMBER_NOTEPADS ];
} RTEMS_API_Control;
typedef struct {
Objects_Control Object;
void (*destructor)( void * );
void **Values[ OBJECTS_APIS_LAST + 1 ];
} POSIX_Keys_Control;
2. I doesn't quite understand the key create procedure.First, I'm not sure
what determines the maximum variable at line4 in code below, is it equal to
CONFIGURE_MAXIMUM_POSIX_KEYS in configuration? Second, where the code also
allocates key memory for OBJECTS_INTERNAL_API, OBJECTS_CLASSIC_API, while
in my opinion, only key memory allocation for OBJECTS_POSIX_API is enough.
what are other things used for?
typedef enum {
OBJECTS_NO_API = 0,
OBJECTS_INTERNAL_API = 1,
OBJECTS_CLASSIC_API = 2,
OBJECTS_POSIX_API = 3
} Objects_APIs;
#define OBJECTS_APIS_LAST OBJECTS_POSIX_API
1 for ( the_api = 1; the_api <= OBJECTS_APIS_LAST; the_api++ ) {
2 the_key->Values[ the_api ] = NULL;
3
4 bytes_to_allocate = sizeof( void * ) * (_Objects_Information_table[
the_api ][ 1 ]->maximum + 1);
5 table = _Workspace_Allocate( bytes_to_allocate );
6 if ( !table ) {
7 _POSIX_Keys_Free_memory( the_key );
8
9 _POSIX_Keys_Free( the_key );
10 _Thread_Enable_dispatch();
11 return ENOMEM;
12 }
13
14 the_key->Values[ the_api ] = table;
15 memset( table, '\0', bytes_to_allocate );
16 }
3. What's the general purpose of Notepads in RTEMS? After look at the
example in /testsuites/sptests/sp07, I feel it is used for inter-thread
communication, am I right? And the same question for POSIX key, since I
haven't found much information of it in RTEMS POSIX API User’s Guide, I
learn POSIX key knowledge from here[2], does it also apply to RTEMS?
4.As mentioned in [1], std::map can be an example for this project. I
wonder is std::vector also appropriate for this project? Or maybe, several
differection algorithms sould be implemented, and leave the choice to user?
And I haven't study hash/map algorithm in depth, maybe, I should ask
related question after do more homework on this.
5. What's the function naming convention in RTEMS, like _POSIX_Key_Get is
an inline function, while _POSIX_Keys_Free_memory is not.
links:
[1]http://www.rtems.com/wiki/index.php/UseHashOrMapInNotepadsAndKeys
[2]http://www.cs.cf.ac.uk/Dave/C/node29.html#SECTION002945000000000000000
Best Regards!
zw_yao
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120330/0515f392/attachment.html>
