Fwd: GCC 4.7.0 Release Candidate available from gcc.gnu.org
Ralf Corsepius ralf.corsepius at rtems.org
Mon Mar 5 18:00:39 UTC 2012
On 03/05/2012 05:11 PM, Sebastian Huber wrote:
> On 03/05/2012 04:39 PM, Ralf Corsepius wrote:
>> On 03/05/2012 12:14 PM, Sebastian Huber wrote:
>>> On 03/05/2012 12:03 PM, Ralf Corsepius wrote:
>>>> arm-rtems* fails with this:
>>>> *** Configuration arm-unknown-rtems4.11 is obsolete.
>>>> *** Specify --enable-obsolete to build it anyway.
>>>> *** Support will be REMOVED in the next major release of GCC,
>>>> *** unless a maintainer comes forward.
>>>> ... I am speechless about this jerkery :(
>>> This configuration is in fact obsolete. Anyone using it should switch to
>>> the EABI configuration as soon as possible.
>> Keyword: _should_ ... compare this to your "short enums" issues.
> Everything has two sides.
>> I read this as "wishful thinking outrules reason and practice".
> You should read this as "it is past time to abandon an obsolete and
> unmaintained configuration". The EABI for ARM is available in GCC since
> 2004.
AFAICT, GCC's EABI had been ignored by many people, because it was in
poor shape for a long time and the only usable EABI compilers had been
commercial.
IIRC, it was you, who had called arm-eabi gcc-4.6.x crap? Do you really
expect it to be better in gcc-4.7.0?
> http://gcc.gnu.org/ml/gcc-patches/2011-12/msg00692.html
If we adhere to GCC's decision, we need to remove the arm-rtems4.11
toolchains and the arm target from RTEMS-4.11 right on the spot.
Ralf
