[PATCH] confdefs: Add declaration for unlimited objects.
Mon Mar 26 21:28:15 UTC 2012
Adds to confdefs a way to specify rtems_resource_unlimited for classic and
posix objects using a new macro CONFIGURE_OBJECTS_UNLIMITED.
Use CONFIGURE_OBJECTS_ALLOCATION_SIZE to declare the allocation size for
extending the set of objects at runtime. Updates the unlimited sample
to demonstrate how to use the new macros.
 cpukit/sapi/include/confdefs.h        |  103 ++++++++++++++++++++++++++++++++-
 testsuites/samples/unlimited/system.h |    3 +-
 2 files changed, 104 insertions(+), 2 deletions(-)
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index 8f03c87..3567ca2 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -1345,6 +1345,107 @@ rtems_fs_init_functions_t    rtems_fs_init_helper =
+ * Unlimited objects
+#if defined(CONFIGURE_UNLIMITED_OBJECTS)
+  #if !defined(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
+    #define CONFIGURE_UNLIMITED_ALLOCATION_SIZE 8
+  #endif
+  #if !defined(CONFIGURE_MAXIMUM_TASKS)
+    #define CONFIGURE_MAXIMUM_TASKS \
+      rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
+  #endif
+  #if !defined(CONFIGURE_MAXIMUM_TIMERS)
+    #define CONFIGURE_MAXIMUM_TIMERS \
+  #endif
+  #if !defined(CONFIGURE_MAXIMUM_SEMAPHORES)
+    #define CONFIGURE_MAXIMUM_SEMAPHORES \
+  #endif
+  #if !defined(CONFIGURE_MAXIMUM_MESSAGE_QUEUES)
+    #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES \
+  #endif
+  #if !defined(CONFIGURE_MAXIMUM_PARTITIONS)
+    #define CONFIGURE_MAXIMUM_PARTITIONS \
+  #endif
+  #if !defined(CONFIGURE_MAXIMUM_REGIONS)
+    #define CONFIGURE_MAXIMUM_REGIONS \
+  #endif
+  #if !defined(CONFIGURE_MAXIMUM_PORTS)
+    #define CONFIGURE_MAXIMUM_PORTS \
+  #endif
+  #if !defined(CONFIGURE_MAXIMUM_PERIODS)
+    #define CONFIGURE_MAXIMUM_PERIODS \
+  #endif
+  #if !defined(CONFIGURE_MAXIMUM_BARRIERS)
+    #define CONFIGURE_MAXIMUM_BARRIERS \
+  #endif
+  #ifdef RTEMS_POSIX_API
+    #if !defined(CONFIGURE_MAXIMUM_POSIX_THREADS)
+      #define CONFIGURE_MAXIMUM_POSIX_THREADS \
+    #endif
+    #if !defined(CONFIGURE_MAXIMUM_POSIX_MUTEXES)
+      #define CONFIGURE_MAXIMUM_POSIX_MUTEXES \
+    #endif
+    #if !defined(CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES)
+      #define CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES \
+    #endif
+    #if !defined(CONFIGURE_MAXIMUM_POSIX_KEYS)
+      #define CONFIGURE_MAXIMUM_POSIX_KEYS \
+    #endif
+    #if !defined(CONFIGURE_MAXIMUM_POSIX_TIMERS)
+      #define CONFIGURE_MAXIMUM_POSIX_TIMERS \
+    #endif
+    #if !defined(CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS)
+      #define CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS \
+    #endif
+    #if !defined(CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES)
+      #define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES \
+    #endif
+    #if !defined(CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS)
+      #define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS \
+    #endif
+    #if !defined(CONFIGURE_MAXIMUM_POSIX_SEMAPHORES)
+      #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES \
+    #endif
+    #if !defined(CONFIGURE_MAXIMUM_POSIX_BARRIERS)
+      #define CONFIGURE_MAXIMUM_POSIX_BARRIERS \
+    #endif
+    #if !defined(CONFIGURE_MAXIMUM_POSIX_RWLOCKS)
+      #define CONFIGURE_MAXIMUM_POSIX_RWLOCKS \
+    #endif
+    #if !defined(CONFIGURE_MAXIMUM_POSIX_SPINLOCKS)
+      #define CONFIGURE_MAXIMUM_POSIX_SPINLOCKS \
+    #endif
+  #endif /* RTEMS_POSIX_API */
+#endif /* CONFIGURE_UNLIMITED_OBJECTS */
  *  Default Configuration Table.
@@ -1548,7 +1649,7 @@ rtems_fs_init_functions_t    rtems_fs_init_helper =
   #define _Configure_POSIX_Named_Object_RAM(_number, _size) \
     _Configure_Object_RAM( (_number), _size ) + \
-    ((_number) * _Configure_From_workspace(NAME_MAX) )
+    (_Configure_Max_Objects(_number) * _Configure_From_workspace(NAME_MAX) )
   #ifndef CONFIGURE_MAXIMUM_POSIX_THREADS
     #define CONFIGURE_MAXIMUM_POSIX_THREADS      0
diff --git a/testsuites/samples/unlimited/system.h b/testsuites/samples/unlimited/system.h
index e1c9cb7..8acbded 100644
--- a/testsuites/samples/unlimited/system.h
+++ b/testsuites/samples/unlimited/system.h
@@ -50,7 +50,8 @@ extern void test3(void);
 #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
 #define TASK_ALLOCATION_SIZE     (5)
-#define CONFIGURE_MAXIMUM_TASKS  rtems_resource_unlimited(TASK_ALLOCATION_SIZE)
+#define CONFIGURE_UNLIMITED_OBJECTS
+#define CONFIGURE_UNLIMITED_ALLOCATION_SIZE TASK_ALLOCATION_SIZE
 #define CONFIGURE_INIT_TASK_STACK_SIZE (8 * 1024)
1.7.4.4
