[PATCH 2/4] libblock: Use unprotected chain operations
sebastian.huber at embedded-brains.de sebastian.huber at embedded-brains.de
Wed Mar 28 13:30:26 UTC 2012
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
The transfer chain is accessed by at most one thread at a time.
 cpukit/libblock/src/bdbuf.c |    8 ++++----
 1 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/cpukit/libblock/src/bdbuf.c b/cpukit/libblock/src/bdbuf.c
index 89951f4..9af2f4a 100644
--- a/cpukit/libblock/src/bdbuf.c
+++ b/cpukit/libblock/src/bdbuf.c
@@ -2269,7 +2269,7 @@ rtems_bdbuf_swapout_write (rtems_bdbuf_swapout_transfer* transfer)
     transfer->write_req->status = RTEMS_RESOURCE_IN_USE;
     transfer->write_req->bufnum = 0;
-    while ((node = rtems_chain_get(&transfer->bds)) != NULL)
+    while ((node = rtems_chain_get_unprotected(&transfer->bds)) != NULL)
       rtems_bdbuf_buffer* bd = (rtems_bdbuf_buffer*) node;
       bool                write = false;
@@ -2291,7 +2291,7 @@ rtems_bdbuf_swapout_write (rtems_bdbuf_swapout_transfer* transfer)
           transfer->write_req->bufnum &&
           (bd->block != (last_block + bufs_per_bd)))
-        rtems_chain_prepend (&transfer->bds, &bd->link);
+        rtems_chain_prepend_unprotected (&transfer->bds, &bd->link);
         write = true;
       else
@@ -2438,7 +2438,7 @@ rtems_bdbuf_swapout_modified_processing (const rtems_disk_device **dd_ptr,
           if (bd->block > tbd->block)
-            rtems_chain_insert (tnode, node);
+            rtems_chain_insert_unprotected (tnode, node);
             node = NULL;
           else
@@ -2446,7 +2446,7 @@ rtems_bdbuf_swapout_modified_processing (const rtems_disk_device **dd_ptr,
         if (node)
-          rtems_chain_prepend (transfer, node);
+          rtems_chain_prepend_unprotected (transfer, node);
         node = next_node;
1.6.4.2
