[PATCH 24] SPARC BSPS: added defines for set_vec type argument to bsp.h
Daniel Hellstrom
daniel at gaisler.com
Thu Mar 29 11:52:15 UTC 2012
Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
c/src/lib/libbsp/sparc/erc32/include/bsp.h | 4 ++++
c/src/lib/libbsp/sparc/erc32/startup/setvec.c | 2 +-
c/src/lib/libbsp/sparc/leon2/include/bsp.h | 4 ++++
c/src/lib/libbsp/sparc/leon2/startup/setvec.c | 2 +-
c/src/lib/libbsp/sparc/leon3/include/bsp.h | 4 ++++
c/src/lib/libbsp/sparc/leon3/startup/setvec.c | 2 +-
6 files changed, 15 insertions(+), 3 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/erc32/include/bsp.h b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
index a88673e..70f1ce3 100644
--- a/c/src/lib/libbsp/sparc/erc32/include/bsp.h
+++ b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
@@ -69,6 +69,10 @@ extern int end; /* last address in the program */
/* functions */
+/* set_vec type */
+#define SET_VECTOR_RAW 0 /* Raw trap handler */
+#define SET_VECTOR_INT 1 /* Trap handler with _ISR_Handler interrupt handler */
rtems_isr_entry set_vector( /* returns old vector */
rtems_isr_entry handler, /* isr routine */
rtems_vector_number vector, /* vector number */
diff --git a/c/src/lib/libbsp/sparc/erc32/startup/setvec.c b/c/src/lib/libbsp/sparc/erc32/startup/setvec.c
index 3a7601d..7e697a0 100644
--- a/c/src/lib/libbsp/sparc/erc32/startup/setvec.c
+++ b/c/src/lib/libbsp/sparc/erc32/startup/setvec.c
@@ -42,7 +42,7 @@ rtems_isr_entry set_vector( /* returns old vector */
uint32_t real_trap;
uint32_t source;
- if ( type )
+ if ( type == SET_VECTOR_INT )
rtems_interrupt_catch( handler, vector, &previous_isr );
else
_CPU_ISR_install_raw_handler( vector, handler, (void *)&previous_isr );
diff --git a/c/src/lib/libbsp/sparc/leon2/include/bsp.h b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
index 796290e..a2f3360 100644
--- a/c/src/lib/libbsp/sparc/leon2/include/bsp.h
+++ b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
@@ -88,6 +88,10 @@ extern int end; /* last address in the program */
/* miscellaneous stuff assumed to exist */
+/* set_vec type */
diff --git a/c/src/lib/libbsp/sparc/leon2/startup/setvec.c b/c/src/lib/libbsp/sparc/leon2/startup/setvec.c
index c7b8af6..028b17a 100644
--- a/c/src/lib/libbsp/sparc/leon2/startup/setvec.c
+++ b/c/src/lib/libbsp/sparc/leon2/startup/setvec.c
uint32_t real_trap;
uint32_t source;
- if ( type )
else
diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp.h b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
index 07a7412..04279d9 100644
--- a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
+++ b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
@@ -98,6 +98,10 @@ extern int end; /* last address in the program */
+/* set_vec type */
diff --git a/c/src/lib/libbsp/sparc/leon3/startup/setvec.c b/c/src/lib/libbsp/sparc/leon3/startup/setvec.c
--- a/c/src/lib/libbsp/sparc/leon3/startup/setvec.c
+++ b/c/src/lib/libbsp/sparc/leon3/startup/setvec.c
uint32_t real_trap;
uint32_t source;
- if ( type )
else
1.7.0.4
