[PATCH 25] LEON3: various cleanups in leon.h
    Daniel Hellstrom
    daniel at gaisler.com
    Thu Mar 29 11:52:16 UTC 2012
Removed old LEON2 definitions never used in LEON3 leon.h.
Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
 c/src/lib/libbsp/sparc/leon3/include/leon.h |   64 +--------------------------
 1 files changed, 1 insertions(+), 63 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/leon3/include/leon.h b/c/src/lib/libbsp/sparc/leon3/include/leon.h
index cd50629..fd208b0 100644
--- a/c/src/lib/libbsp/sparc/leon3/include/leon.h
+++ b/c/src/lib/libbsp/sparc/leon3/include/leon.h
@@ -46,67 +46,6 @@ extern "C" {
   ( (_trap) >= 0x11 && \
     (_trap) <= 0x1F )
- *  Structure for LEON memory mapped registers.
- *  Source: Section 6.1 - On-chip registers
- *  NOTE:  There is only one of these structures per CPU, its base address
- *         is 0x80000000, and the variable LEON_REG is placed there by the
- *         linkcmds file.
-/* Leon uses dynamic register mapping using amba configuration records,
- * LEON_Register_Map is obsolete
-  typedef struct {
-	volatile unsigned int Memory_Config_1;
-	volatile unsigned int Memory_Config_2;
-	volatile unsigned int Edac_Control;
-	volatile unsigned int Failed_Address;
-	volatile unsigned int Memory_Status;
-	volatile unsigned int Cache_Control;
-	volatile unsigned int Power_Down;
-	volatile unsigned int Write_Protection_1;
-	volatile unsigned int Write_Protection_2;
-	volatile unsigned int Leon_Configuration;
-	volatile unsigned int dummy2;
-	volatile unsigned int dummy3;
-	volatile unsigned int dummy4;
-	volatile unsigned int dummy5;
-	volatile unsigned int dummy6;
-	volatile unsigned int dummy7;
-	volatile unsigned int Timer_Counter_1;
-	volatile unsigned int Timer_Reload_1;
-	volatile unsigned int Timer_Control_1;
-	volatile unsigned int Watchdog;
-	volatile unsigned int Timer_Counter_2;
-	volatile unsigned int Timer_Reload_2;
-	volatile unsigned int Timer_Control_2;
-	volatile unsigned int dummy8;
-	volatile unsigned int Scaler_Counter;
-	volatile unsigned int Scaler_Reload;
-	volatile unsigned int dummy9;
-	volatile unsigned int dummy10;
-	volatile unsigned int UART_Channel_1;
-	volatile unsigned int UART_Status_1;
-	volatile unsigned int UART_Control_1;
-	volatile unsigned int UART_Scaler_1;
-	volatile unsigned int UART_Channel_2;
-	volatile unsigned int UART_Status_2;
-	volatile unsigned int UART_Control_2;
-	volatile unsigned int UART_Scaler_2;
-	volatile unsigned int Interrupt_Mask;
-	volatile unsigned int Interrupt_Pending;
-	volatile unsigned int Interrupt_Force;
-	volatile unsigned int Interrupt_Clear;
-	volatile unsigned int PIO_Data;
-	volatile unsigned int PIO_Direction;
-	volatile unsigned int PIO_Interrupt;
-} LEON_Register_Map;
 typedef struct {
   volatile unsigned int data;
   volatile unsigned int status;
@@ -193,7 +132,6 @@ typedef struct {
 #define LEON_REG_UART_STATUS_FE   0x00000040 /* RX Framing Error */
 #define LEON_REG_UART_STATUS_ERR  0x00000078 /* Error Mask */
  *  The following defines the bits in the LEON UART Status Registers.
@@ -211,6 +149,7 @@ extern volatile LEON3_IrqCtrl_Regs_Map *LEON3_IrqCtrl_Regs;  /* LEON3 Interrupt
 extern volatile LEON3_Timer_Regs_Map *LEON3_Timer_Regs; /* LEON3 GP Timer */
 extern volatile LEON3_UART_Regs_Map *LEON3_Console_Uart[LEON3_APBUARTS];
+/* LEON3 CPU Index of boot CPU */
 extern int LEON3_Cpu_Index;
 /* Macros used for manipulating bits in LEON3 GP Timer Control Register */
@@ -256,7 +195,6 @@ extern int LEON3_Cpu_Index;
      (LEON3_IrqCtrl_Regs->mask[LEON3_Cpu_Index] & (1 << (_source))); \
    } while (0)
 #define LEON_Mask_interrupt( _source ) \
   do { \
     uint32_t _level; \
1.7.0.4
