[PR 20] LEON3: fix GRETH interrupt initialization bug
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Mar 29 14:20:47 UTC 2012
This should be committed now.
On 03/29/2012 06:52 AM, Daniel Hellstrom wrote:
> Fixed a bug where the vector number is used to clean and unmask
> the IRQ at the IRQ controller, the irq number must be used.
> Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
> .../lib/libbsp/sparc/leon3/leon_greth/leon_greth.c | 8 ++++----
> 1 files changed, 4 insertions(+), 4 deletions(-)
> diff --git a/c/src/lib/libbsp/sparc/leon3/leon_greth/leon_greth.c b/c/src/lib/libbsp/sparc/leon3/leon_greth/leon_greth.c
> index 341bd27..dd301d7 100644
> --- a/c/src/lib/libbsp/sparc/leon3/leon_greth/leon_greth.c
> +++ b/c/src/lib/libbsp/sparc/leon3/leon_greth/leon_greth.c
> @@ -41,19 +41,19 @@ int rtems_leon_greth_driver_attach(
> if (device_found == 1)
> base_addr = apbgreth.start;
> - eth_irq = apbgreth.irq + 0x10;
> + eth_irq = apbgreth.irq;
> /* clear control register and reset NIC */
> *(volatile int *) base_addr = 0;
> *(volatile int *) base_addr = GRETH_CTRL_RST;
> leon_greth_configuration.base_address = base_addr;
> - leon_greth_configuration.vector = eth_irq;
> + leon_greth_configuration.vector = eth_irq + 0x10;
> leon_greth_configuration.txd_count = TDA_COUNT;
> leon_greth_configuration.rxd_count = RDA_COUNT;
> if (rtems_greth_driver_attach( config,&leon_greth_configuration )) {
> - LEON_Clear_interrupt(leon_greth_configuration.vector);
> - LEON_Unmask_interrupt(leon_greth_configuration.vector);
> + LEON_Clear_interrupt(eth_irq);
> + LEON_Unmask_interrupt(eth_irq);
> return 0;
Joel Sherrill, Ph.D. Director of Research& Development
