[PATCH 24] SPARC BSPS: added defines for set_vec type argument to bsp.h
Gedare Bloom
gedare at rtems.org
Thu Mar 29 19:54:10 UTC 2012
I do like the idea of pushing the macro up so that other architectures
will implement it, but I'm not sure where the macro should live in
that case.
Renaming it is a good idea but clearly requires more consideration.
On Thu, Mar 29, 2012 at 3:48 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On 03/29/2012 02:45 PM, Gedare Bloom wrote:
>> looks good
> I am OK with it also but it seems like set_vector() is a
> required part of BSPs for the Simple Vectored Architectures.
> Shouldn't the prototype and any constants associated
> with it be in a common header file?
> And maybe (I hate to suggest this), it be renamed
> to bsp_set_vector() per current naming guidelines.
>> On Thu, Mar 29, 2012 at 7:52 AM, Daniel Hellstrom<daniel at gaisler.com>
>> wrote:
>>> Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
>>> c/src/lib/libbsp/sparc/erc32/include/bsp.h | 4 ++++
>>> c/src/lib/libbsp/sparc/erc32/startup/setvec.c | 2 +-
>>> c/src/lib/libbsp/sparc/leon2/include/bsp.h | 4 ++++
>>> c/src/lib/libbsp/sparc/leon2/startup/setvec.c | 2 +-
>>> c/src/lib/libbsp/sparc/leon3/include/bsp.h | 4 ++++
>>> c/src/lib/libbsp/sparc/leon3/startup/setvec.c | 2 +-
>>> 6 files changed, 15 insertions(+), 3 deletions(-)
>>> diff --git a/c/src/lib/libbsp/sparc/erc32/include/bsp.h
>>> b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
>>> index a88673e..70f1ce3 100644
>>> --- a/c/src/lib/libbsp/sparc/erc32/include/bsp.h
>>> +++ b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
>>> @@ -69,6 +69,10 @@ extern int end; /* last address in the
>>> program */
>>> /* functions */
>>> +/* set_vec type */
>>> +#define SET_VECTOR_RAW 0 /* Raw trap handler */
>>> +#define SET_VECTOR_INT 1 /* Trap handler with _ISR_Handler interrupt
>>> handler */
>>> rtems_isr_entry set_vector( /* returns old vector */
>>> rtems_isr_entry handler, /* isr routine */
>>> rtems_vector_number vector, /* vector number */
>>> diff --git a/c/src/lib/libbsp/sparc/erc32/startup/setvec.c
>>> b/c/src/lib/libbsp/sparc/erc32/startup/setvec.c
>>> index 3a7601d..7e697a0 100644
>>> --- a/c/src/lib/libbsp/sparc/erc32/startup/setvec.c
>>> +++ b/c/src/lib/libbsp/sparc/erc32/startup/setvec.c
>>> @@ -42,7 +42,7 @@ rtems_isr_entry set_vector( /*
>>> uint32_t real_trap;
>>> uint32_t source;
>>> - if ( type )
>>> + if ( type == SET_VECTOR_INT )
>>> rtems_interrupt_catch( handler, vector,&previous_isr );
>>> else
>>> _CPU_ISR_install_raw_handler( vector, handler, (void *)&previous_isr
>>> diff --git a/c/src/lib/libbsp/sparc/leon2/include/bsp.h
>>> b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
>>> index 796290e..a2f3360 100644
>>> --- a/c/src/lib/libbsp/sparc/leon2/include/bsp.h
>>> +++ b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
>>> @@ -88,6 +88,10 @@ extern int end; /* last address in the
>>> program */
>>> /* miscellaneous stuff assumed to exist */
>>> +/* set_vec type */
>>> handler */
>>> diff --git a/c/src/lib/libbsp/sparc/leon2/startup/setvec.c
>>> b/c/src/lib/libbsp/sparc/leon2/startup/setvec.c
>>> index c7b8af6..028b17a 100644
>>> --- a/c/src/lib/libbsp/sparc/leon2/startup/setvec.c
>>> +++ b/c/src/lib/libbsp/sparc/leon2/startup/setvec.c
>>> uint32_t real_trap;
>>> uint32_t source;
>>> - if ( type )
>>> else
>>> diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>>> b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>>> index 07a7412..04279d9 100644
>>> --- a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>>> +++ b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>>> @@ -98,6 +98,10 @@ extern int end; /* last address in the
>>> program */
>>> +/* set_vec type */
>>> handler */
>>> diff --git a/c/src/lib/libbsp/sparc/leon3/startup/setvec.c
>>> b/c/src/lib/libbsp/sparc/leon3/startup/setvec.c
>>> --- a/c/src/lib/libbsp/sparc/leon3/startup/setvec.c
>>> +++ b/c/src/lib/libbsp/sparc/leon3/startup/setvec.c
>>> uint32_t real_trap;
>>> uint32_t source;
>>> - if ( type )
>>> else
>>> 1.7.0.4
>>> rtems-devel mailing list
>>> rtems-devel at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-devel
> Joel Sherrill, Ph.D. Director of Research& Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
