Fwd: lrzip: extreme compression (but beware its slow decompression speed)
Ralf Corsepius ralf.corsepius at rtems.org
Fri Mar 30 17:37:39 UTC 2012
On 03/30/2012 07:05 PM, Joel Sherrill wrote:
> Interesting study of compression programs on gcc's tarball.
Yes, an interesting summary.
> The size vs time is interesting.
Well, Jim had posted similar statistics to Fedora and automake lists
several times before.
  His activities in the end had led Fedora to choose xz (Fedora's and
CentOS 6's rpm uses xz to compress its payload) and to choose customized
compression levels for xz which result into much better compression than
bz2 at comparable decompression times.
  He recently did something similar for automake. AFAIK, the next
release of automake (scheduled to be release for next week), will
contain reflections of his experiments.
There is one issue with xz, Jim usually doesn't mention  ;):
  xz is much more memory-demanding than gz or bz2.
That said, as mentioned elsewhere before, I am considering to use
self-built/repackaged *.xz compressed gcc tarballs instead of the
original gnu.org compressed gcc*.bz2 tarballs for building the rpms.
The reduction of package sizes, corresponding reduction of discspace on
mirrors and improvements on building speed (During builds these files a
copied over nfs) is overwhelming, IMNSHO.
Ralf
