[PATCH 4/4] score/rbtree: eliminate unused function _RBTree_Peek.
Wed May 2 17:03:35 UTC 2012
Hard patch to argue against. OK to commit when
the time is right.
On 05/02/2012 11:35 AM, Gedare Bloom wrote:
>   cpukit/score/Makefile.am                  |    3 +-
>   cpukit/score/include/rtems/score/rbtree.h |   17 ----------
>   cpukit/score/src/rbtreepeek.c             |   49 -----------------------------
>   3 files changed, 1 insertions(+), 68 deletions(-)
>   delete mode 100644 cpukit/score/src/rbtreepeek.c
> diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
> index 2f12905..2ff6b54 100644
> --- a/cpukit/score/Makefile.am
> +++ b/cpukit/score/Makefile.am
> @@ -265,8 +265,7 @@ libscore_a_SOURCES += src/pheapallocate.c \
>   ## RBTREE_C_FILES
>   libscore_a_SOURCES += src/rbtree.c \
>       src/rbtreeextract.c src/rbtreefind.c src/rbtreefindheader.c \
> -    src/rbtreeget.c src/rbtreeinsert.c src/rbtreepeek.c src/rbtreenext.c \
> -    src/rbtreeiterate.c
> +    src/rbtreeget.c src/rbtreeinsert.c src/rbtreeiterate.c src/rbtreenext.c
>   ## THREAD_C_FILES
>   libscore_a_SOURCES += src/thread.c src/threadchangepriority.c \
> diff --git a/cpukit/score/include/rtems/score/rbtree.h b/cpukit/score/include/rtems/score/rbtree.h
> index 2e9bb83..d98392e 100644
> --- a/cpukit/score/include/rtems/score/rbtree.h
> +++ b/cpukit/score/include/rtems/score/rbtree.h
> @@ -220,23 +220,6 @@ RBTree_Node *_RBTree_Get(
> - *  @brief Check the min or max node on a rbtree
> - *  This function returns a pointer to the min or max node of @a the_rbtree.
> - *  If @a the_rbtree is empty, then NULL is returned. @a dir specifies
> - *  whether to return the min (0) or max (1).
> - *  @return This method returns a pointer to a node.
> - *          If @a the_rbtree was empty, then NULL is returned.
> - *  @note It disables interrupts to ensure the atomicity of the get operation.
> -RBTree_Node *_RBTree_Peek(
> -  const RBTree_Control *the_rbtree,
> -  RBTree_Direction dir
>    * @brief Find the node with given key in the tree
>    *  This function returns a pointer to the node with key equal to a key
> diff --git a/cpukit/score/src/rbtreepeek.c b/cpukit/score/src/rbtreepeek.c
> deleted file mode 100644
> index 81ff0fd..0000000
> --- a/cpukit/score/src/rbtreepeek.c
> +++ /dev/null
> @@ -1,49 +0,0 @@
> - *  Copyright (c) 2010-2012 Gedare Bloom.
> - *  The license and distribution terms for this file may be
> - *  found in the file LICENSE in this distribution or at
> - *  http://www.rtems.com/license/LICENSE.
> -#if HAVE_CONFIG_H
> -#include "config.h"
> -#endif
> -#include<rtems/system.h>
> -#include<rtems/score/address.h>
> -#include<rtems/score/rbtree.h>
> -#include<rtems/score/isr.h>
> - *  _RBTree_Get
> - *  This kernel routine returns a pointer to the min or max node on the tree,
> - *  without removing that node.
> - *  Input parameters:
> - *    the_rbtree - pointer to rbtree header
> - *    dir - specifies whether to return minimum (0) or maximum (1)
> - *  Output parameters:
> - *    return_node - pointer to node in rbtree allocated
> - *    NULL   - if no nodes available
> - *  INTERRUPT LATENCY:
> - *    only case
> -  ISR_Level          level;
> -  RBTree_Node *return_node;
> -  return_node = NULL;
> -  _ISR_Disable( level );
> -      return_node = _RBTree_First( the_rbtree, dir );
> -  _ISR_Enable( level );
> -  return return_node;
Joel Sherrill, Ph.D.             Director of Research&   Development
