RFC: Removing $Id$
Wed May 2 18:26:24 UTC 2012
A quick inspection shows there is also:
//    $Id$
/*   $Id$     */
$Id$ showing up all by itself
| $Id$
And $Id$ used as part of a macro c.f. ./cpukit/pppd/utils.c:#define RCSID	"$Id$"
-Gedare
On Wed, May 2, 2012 at 2:06 PM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
> On 05/02/2012 12:44 PM, Ralf Corsepius wrote:
>> On 05/02/2012 07:15 PM, Joel Sherrill wrote:
>>> Hi
>>> We apparently didn't reach an obvious consensus
>>> on removing $Id$ from every file that originated
>>> from RTEMS.[1]
>>> IMO it is time to remove this relic.
>> I agree, that these $Id$ now are meaningless and can be removed.
>>> Any objections.
>> My remark from previous discussion still remains:
>> Does git have a counterpart to $Id$, which can be used to identify the
>> version of a file?
> I couldn't find anything that either didn't devolve to a hash
> and/or require something special on the client side.  I didn't
> think that having special plugins on the user side would be
> desirable.
> We don't tend to use the Ids much in bug reporting discussions.
> I don't know that they are as useful as they are something
> we are used to having.
> If someone's Google-foo turns up something, we can
> certainly consider it. But it is a non-starter with git
> from my research.
> Ralf.. you are pretty good at this type of script. If you are
> up for doing this and no one objects, it would be appreciated.
> The only caveats I see if that files often have this pattern (1)
>  *  $Id$
> Or ...
>  *  $Id$
>  *  Some text
> It may be necessary to crunch two comments lines into 1 after
> removing the $Id$.
> The other pattern is in configure.ac and Makefile.am files
> which often only have a comment block which doesn't have
> much other then the $Id$ in it. What makes sense to leave?
> ## Process this file with autoconf to produce a configure script.
> ## $Id$
> What should that look like afterwards?
> I think most, if not all assembly, follows the C style rules for
> file headers so should be the same as C files.
>>> [1] No changes to *BSD, httpd, rpc/xdr or other third party
>>> originated code to be made.
>> These files usually carry RTEMS-CVS $Id$ (modulo bugs), which should be
>> subject to the same treatment as all other $Id$, but carry additional
>> protected/special $Id$s, which had been necessary to protect them from
>> RTEMS-CVS modifying these files' original $Id$s
> Agreed for *BSD code. Each library would have to be examined
> to ensure the proper rule to apply.
>> Ralf
> Joel Sherrill, Ph.D.             Director of Research&   Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>    Support Available             (256) 722-9985
> rtems-devel mailing list
> rtems-devel at rtems.org
