[PATCH] testsuites - remove all $Id$ strings
Thu May 3 15:46:16 UTC 2012
Do you have a branch / link to the patch or was it supposed to
accompany your email?
On Thu, May 3, 2012 at 11:19 AM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> This is a patch to remove all CVS Id strings from the testsuites.
> It is completely done by a shell script with much help from sed.
> I tried to take into acount a number of odd cases:
> + Removed enough to avoid two blank comment lines
> + Removed file headers with only Id string
>  - In some cases, I fixed files to have copyright or
>    properly formatted headers before running script.
> + Removed blank first line at top of file if sed left it.
> I tested most of the patterns on individual files.
> I perused the diff but it is large.  Since this is a
> big patch and mechanical, I would appreciate a review.
> Thanks.
> --joel
> rtems-devel mailing list
> rtems-devel at rtems.org
