Continuous Integration - rtbf64c
Fri May 4 02:40:17 UTC 2012
Hello,
A long term goal of the RTEMS project is to support continuous
integration. Continuous integrations takes patches and commits and
builds and tests them providing public reporting of the results. Adding
continuous integration to the project provides better turn around for
changes that effect different architectures or BSPs lowering the work
load on the RTEMS maintainers who have commit access. It allows
different configurations to be tested that are often missed or nor done
because of time and resource reasons, exposing any issues a patch may
have when it goes in rather than some other point in time. The net
effect is the improvement of the RTEMS code base as well as visible
reporting of the current build state.
The first stage of this work was the conversion to git providing us with
change sets. We are now starting on the next stage, bringing a buildbot
server online. This stage will allow us to better examine the build
system and configuration in RTEMS and to look at ways to improve its
performance so we can get the best out of the infrastructure resources
we have. In the future we will add a patch management tool which will
allow better testing and reporting on specific patches.
The RTEMS server, rtbf64c, purchased to perform this task, will be taken
off line in 48 hours time and reconfigured to support the continuous
integration effort. If you have access to the machine and have anything
you wish to keep please move it to another machine.
Any testing or tool building tasks that are not critical should look to
using the other hardware we have available.
Thanks.
