[rtems commit] Remove CVS-Ids.
Fri May 4 13:40:06 UTC 2012
Stop this!
Ralf Corsepius <ralf at rtems.org> wrote:
>Module:    rtems
>Branch:    4.10
>Commit:    90e8181bd0df4124c56417f8819cd5c1cbd56fbb
>Changeset: http://git.rtems.org/rtems/commit/?id=90e8181bd0df4124c56417f8819cd5c1cbd56fbb
>Author:    Ralf Corsépius <ralf.corsepius at rtems.org>
>Date:      Fri May  4 11:07:16 2012 +0200
>Remove CVS-Ids.
> Makefile.am                       |    3 ---
> aclocal/bsp-alias.m4              |    4 ----
> aclocal/canonical-target-name.m4  |    4 ----
> aclocal/check-bsps.m4             |    2 --
> aclocal/check-custom-bsp.m4       |    2 --
> aclocal/enable-cxx.m4             |    2 --
> aclocal/enable-itron.m4           |    2 --
> aclocal/enable-multiprocessing.m4 |    2 --
> aclocal/enable-networking.m4      |    2 --
> aclocal/enable-posix.m4           |    2 --
> aclocal/enable-rtems-debug.m4     |    2 --
> aclocal/enable-rtemsbsp.m4        |    2 --
> aclocal/enable-tests.m4           |    2 --
> aclocal/path-ksh.m4               |    2 --
> aclocal/project-root.m4           |    5 -----
> aclocal/rtems-top.m4              |    2 --
> automake/host.am                  |    2 --
> automake/local.am                 |    2 --
> automake/subdirs.am               |    2 --
> configure.ac                      |    2 --
> make/Makefile.am                  |    4 ----
> 21 files changed, 0 insertions(+), 52 deletions(-)
>diff --git a/Makefile.am b/Makefile.am
>index 72e3149..5b4e033 100644
>--- a/Makefile.am
>+++ b/Makefile.am
>@@ -1,9 +1,6 @@
> # top level directory for RTEMS build tree
>-## $Id$
> ACLOCAL_AMFLAGS = -I aclocal
>diff --git a/aclocal/bsp-alias.m4 b/aclocal/bsp-alias.m4
>index 8a9b21a..9aafbcc 100644
>--- a/aclocal/bsp-alias.m4
>+++ b/aclocal/bsp-alias.m4
>@@ -1,7 +1,3 @@
>-dnl
>-dnl  $Id$
>-dnl
> dnl _RTEMS_BSP_ALIAS(BSP_ALIAS,RTEMS_BSP_FAMILY)
> dnl Internal subroutine to RTEMS_BSP_ALIAS
> AC_DEFUN([_RTEMS_BSP_ALIAS],
>diff --git a/aclocal/canonical-target-name.m4 b/aclocal/canonical-target-name.m4
>index ea55376..6870bbf 100644
>--- a/aclocal/canonical-target-name.m4
>+++ b/aclocal/canonical-target-name.m4
>@@ -1,7 +1,3 @@
>-dnl
>-dnl $Id$
>-dnl
> dnl canonicalize target cpu
> dnl NOTE: Most rtems targets do not fullfil autoconf's
> dnl target naming conventions "processor-vendor-os"
>diff --git a/aclocal/check-bsps.m4 b/aclocal/check-bsps.m4
>index 27a4c41..500fcc8 100644
>--- a/aclocal/check-bsps.m4
>+++ b/aclocal/check-bsps.m4
>@@ -1,5 +1,3 @@
>-dnl $Id$
> dnl Report all available bsps for a target within the source tree
> dnl
> dnl RTEMS_CHECK_BSPS(bsp_list)
>diff --git a/aclocal/check-custom-bsp.m4 b/aclocal/check-custom-bsp.m4
>index c4ea9d4..43b379c 100644
>--- a/aclocal/check-custom-bsp.m4
>+++ b/aclocal/check-custom-bsp.m4
>@@ -1,5 +1,3 @@
>-dnl $Id$
> AC_DEFUN([_RTEMS_CHECK_CUSTOM_BSP],[
> AC_REQUIRE([RTEMS_CANONICAL_TARGET_CPU])dnl sets RTEMS_CPU, target
> AC_REQUIRE([RTEMS_TOP])dnl sets RTEMS_TOPdir
>diff --git a/aclocal/enable-cxx.m4 b/aclocal/enable-cxx.m4
>index 8648743..ddd37dc 100644
>--- a/aclocal/enable-cxx.m4
>+++ b/aclocal/enable-cxx.m4
>@@ -1,5 +1,3 @@
>-dnl $Id$
> AC_DEFUN([RTEMS_ENABLE_CXX],
> AC_ARG_ENABLE(cxx,
>diff --git a/aclocal/enable-itron.m4 b/aclocal/enable-itron.m4
>index 2cbdc77..98668dd 100644
>--- a/aclocal/enable-itron.m4
>+++ b/aclocal/enable-itron.m4
>@@ -1,5 +1,3 @@
>-dnl $Id$
> AC_DEFUN([RTEMS_ENABLE_ITRON],
> AC_ARG_ENABLE(itron,
>diff --git a/aclocal/enable-multiprocessing.m4 b/aclocal/enable-multiprocessing.m4
>index 175de9c..8707c9e 100644
>--- a/aclocal/enable-multiprocessing.m4
>+++ b/aclocal/enable-multiprocessing.m4
>@@ -1,5 +1,3 @@
>-dnl $Id$
> AC_DEFUN([RTEMS_ENABLE_MULTIPROCESSING],
> AC_ARG_ENABLE(multiprocessing,
>diff --git a/aclocal/enable-networking.m4 b/aclocal/enable-networking.m4
>index df02ef2..7cede53 100644
>--- a/aclocal/enable-networking.m4
>+++ b/aclocal/enable-networking.m4
>@@ -1,5 +1,3 @@
>-dnl $Id$
> AC_DEFUN([RTEMS_ENABLE_NETWORKING],
> ## AC_BEFORE([$0], [RTEMS_CHECK_NETWORKING])dnl
>diff --git a/aclocal/enable-posix.m4 b/aclocal/enable-posix.m4
>index 1d55432..272704c 100644
>--- a/aclocal/enable-posix.m4
>+++ b/aclocal/enable-posix.m4
>@@ -1,5 +1,3 @@
>-dnl $Id$
> AC_DEFUN([RTEMS_ENABLE_POSIX],
> ## AC_BEFORE([$0], [RTEMS_CHECK_POSIX_API])dnl
>diff --git a/aclocal/enable-rtems-debug.m4 b/aclocal/enable-rtems-debug.m4
>index 1edcea0..18bb67f 100644
>--- a/aclocal/enable-rtems-debug.m4
>+++ b/aclocal/enable-rtems-debug.m4
>@@ -1,5 +1,3 @@
>-## $Id$
> AC_DEFUN([RTEMS_ENABLE_RTEMS_DEBUG],
> AC_ARG_ENABLE(rtems-debug,
>diff --git a/aclocal/enable-rtemsbsp.m4 b/aclocal/enable-rtemsbsp.m4
>index d8ffc55..613a29e 100644
>--- a/aclocal/enable-rtemsbsp.m4
>+++ b/aclocal/enable-rtemsbsp.m4
>@@ -1,5 +1,3 @@
>-dnl $Id$
> dnl Override the set of BSPs to be built.
> dnl used by the toplevel configure script
> dnl RTEMS_ENABLE_RTEMSBSP(rtems_bsp_list)
>diff --git a/aclocal/enable-tests.m4 b/aclocal/enable-tests.m4
>index a48168f..9fb7fa0 100644
>--- a/aclocal/enable-tests.m4
>+++ b/aclocal/enable-tests.m4
>@@ -1,5 +1,3 @@
>-dnl $Id$
> AC_DEFUN([RTEMS_ENABLE_TESTS],
> AC_ARG_ENABLE(tests,
>diff --git a/aclocal/path-ksh.m4 b/aclocal/path-ksh.m4
>index 306c4ca..2c79b31 100644
>--- a/aclocal/path-ksh.m4
>+++ b/aclocal/path-ksh.m4
>@@ -1,5 +1,3 @@
>-dnl $Id$
> AC_DEFUN([RTEMS_PATH_KSH],
> dnl NOTE: prefer bash over ksh over sh
>diff --git a/aclocal/project-root.m4 b/aclocal/project-root.m4
>index 2f27bfe..2649a76 100644
>--- a/aclocal/project-root.m4
>+++ b/aclocal/project-root.m4
>@@ -1,8 +1,3 @@
>-dnl
>-dnl $Id$
>-dnl
>-dnl
> dnl PROJECT_TOPdir     .. relative path to the top of the build-tree
> dnl PROJECT_ROOT       .. relative path to the top of the temporary
> dnl                       installation directory inside the build-tree
>diff --git a/aclocal/rtems-top.m4 b/aclocal/rtems-top.m4
>index 8c76f89..50a57a5 100644
>--- a/aclocal/rtems-top.m4
>+++ b/aclocal/rtems-top.m4
>@@ -1,5 +1,3 @@
>-dnl $Id$
> # AC_DISABLE_OPTION_CHECKING is not available before 2.62
> AC_PREREQ(2.62)
>diff --git a/automake/host.am b/automake/host.am
>index 4a7aa2d..7367d00 100644
>--- a/automake/host.am
>+++ b/automake/host.am
>@@ -1,5 +1,3 @@
>-## $Id$
> ## NOTE: This is a temporary work-around to keep
> ## RTEMS's non automake standard make targets working.
> ## Once automake is fully integrated these make targets
>diff --git a/automake/local.am b/automake/local.am
>index c170178..4de51e5 100644
>--- a/automake/local.am
>+++ b/automake/local.am
>@@ -1,5 +1,3 @@
>-## $Id$
> preinstall-am: $(PREINSTALL_FILES)
> preinstall: preinstall-am
> .PHONY: preinstall preinstall-am
>diff --git a/automake/subdirs.am b/automake/subdirs.am
>index 00eba7c..7ebc65a 100644
>--- a/automake/subdirs.am
>+++ b/automake/subdirs.am
>@@ -1,5 +1,3 @@
>-## $Id$
> ## Borrowed from automake-1.4 and adapted to RTEMS
>diff --git a/configure.ac b/configure.ac
>index 597115e..f7d86a4 100644
>--- a/configure.ac
>+++ b/configure.ac
>@@ -1,6 +1,4 @@
> ## Process this file with autoconf to produce a configure script.
>-## $Id$
> AC_PREREQ([2.68])
> AC_INIT([rtems],[_RTEMS_VERSION],[http://www.rtems.org/bugzilla])
>diff --git a/make/Makefile.am b/make/Makefile.am
>index ee0f6e8..2ac9ff4 100644
>--- a/make/Makefile.am
>+++ b/make/Makefile.am
>@@ -1,7 +1,3 @@
>-## $Id$
> rtems_makedir = $(prefix)/make
> dist_rtems_make_DATA = main.cfg leaf.cfg
>_______________________________________________
>rtems-vc mailing list
>rtems-vc at rtems.org
>http://www.rtems.org/mailman/listinfo/rtems-vc
