[rtems commit] Remove CVS-Ids.
Fri May 4 13:59:31 UTC 2012
Your changes were questioned on the head as a starting point.
You are now taking unapproved patches and applying them to a release branch. Removing Ids from a release branch is a matter which needs to be discussed independent. It is a LOT of edits which do not address bugs. They are not absolutely required to be on a release branch.
This is a community and you need to listen, discuss, and act with the best interests of the community in mind. You are acting unilaterally and ignoring others. This is not YOUR project alone to do with as you please.
--joel
Ralf Corsepius <ralf.corsepius at rtems.org> wrote:
>On 05/04/2012 03:40 PM, Joel Sherrill wrote:
>> Stop this!
>What is your problem?
