fsync() for FAT file system
Sebastian Huber
Fri May 4 14:25:17 UTC 2012
Hi,
currently the fsync() handler for FAT file systems looks like this:
/* fat_file_datasync --
* Synchronize fat-file - flush all buffered data to the media.
* PARAMETERS:
* mt_entry - mount table entry
* fat_fd - fat-file descriptor
* RETURNS:
* RC_OK on success, or -1 if error occured and errno set appropriately
int
fat_file_datasync(
rtems_filesystem_mount_table_entry_t *mt_entry,
fat_file_fd_t *fat_fd
int rc = RC_OK;
rtems_status_code sc = RTEMS_SUCCESSFUL;
fat_fs_info_t *fs_info = mt_entry->fs_info;
uint32_t cur_cln = fat_fd->cln;
rtems_bdbuf_buffer *block = NULL;
uint32_t sec = 0;
uint32_t i = 0;
if (fat_fd->fat_file_size == 0)
return RC_OK;
* we can use only one bdbuf :( and we also know that cache is useless
* for sync operation, so don't use it
rc = fat_buf_release(fs_info);
if (rc != RC_OK)
return rc;
/* for each cluster of the file ... */
while ((cur_cln & fs_info->vol.mask) < fs_info->vol.eoc_val)
sec = fat_cluster_num_to_sector_num(mt_entry, cur_cln);
/* for each sector in cluster ... */
for ( i = 0; i < fs_info->vol.spc; i++ )
/* ... sync it */
sc = rtems_bdbuf_read(fs_info->vol.dd, (sec + i), &block);
if (sc != RTEMS_SUCCESSFUL)
rtems_set_errno_and_return_minus_one( EIO );
sc = rtems_bdbuf_sync(block);
if ( sc != RTEMS_SUCCESSFUL )
rc = fat_get_fat_cluster(mt_entry, cur_cln, &cur_cln);
if ( rc != RC_OK )
return rc;
return rc;
This function will read every cluster of the file into the cache and then
synchronize it step-by-step. For unmodified buffers this is a non-operation.
For modified buffers this will wake-up the swapout task which performs then a
single buffer write operation. This is usually quite inefficient. Firstly we
do single buffer writes and secondly we may perform a lot of unnecessary read
operations.
I think we should replace this synchronization procedure with a simple
rtems_bdbuf_sync_dev(fs_info->vol.dev). This has the side-effect that also
buffers not related to the file are synchronized, but I think this is acceptable.
What do you think?
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
