Ralf's Remove CVS Id Commits
Ralf Corsepius ralf.corsepius at rtems.org
Fri May 4 14:44:36 UTC 2012
On 05/04/2012 04:10 PM, Thomas Doerfler wrote:
> Ralf,
> removing the $Id$ stuff in the sources and build files surely is ONE
> activity, which should be done or not. Commiting this is tiny steps is
> quite similar to changing a source file with one separate patch per code
> line.
> These changes belong together. Nobody wants this change to be done in
> one BSP and NOT done in a different one.
Did you actually have a look into the patches?
> Maybe you should get familiar with the idea that git does apply patches
> in an atomic way and not in a uncorrelated file-by-file basis as CVS does.
The mashing up of the commit messages wasn't done by CVS. It was the
tool being used to produce the commit messages, which was polling at 1
hour intervals and glueing together independent commits.
Ralf
